Hi Jess,
Â
We try to understand you right.
I guess you mean ‘how to make your PC communicate to 3499A and/or 34401A’?
As far I know, 3499A and 34401A should not able communicate by them self to each other.
Â
After you add both instruments in IO Manager of VEE, both programming manuals should able to tell you the commands syntax to perform your desired function/operation. Direct I/O object in VEE could do most of the cases. More examples are documented in manuals too.
Â
Hope this help.
Â
Â
-Edwin
Â
Â
 _____ Â
Sent: Thursday, October 26, 2006 5:02 PM
To: VRF
Subject: [vrf] Switch control and DMM using VEE, HOW~?
Â
Hi folks...
I got some doubt how to start on a switch control system and a digital multimeter using Agilent VEE.
Need to test on switch control in model: Agilent 3499A, and digital multimeter in model: Agilent 34401A.
Using Agilent VEE, how to make this two instruments communicate with each other, specially during switching, latching and non-latching?
I tried to find some example from internet, but cant get any....
I've created a sample code using Agilent Sample Code Wizard, but the problem is how do i apply this code in my VEE?
Gimme some idea pls.....
Â
thanks and regards,
Jess You
Â
Â
Â
Â
Â
Hope this help.
Â
Â
-Edwin
Â
Â
 _____ Â
To: VRF
Â
Hi folks...
Â
thanks and regards,
Jess You
Â
Â
Â
thanks and regards,
Jess You
Â
--- To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body. To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/".
