Ash -
> I changed the Receive and
> Transmit buffer settings in
> Device Manager -Port settings-
> Advanced --- to a reduced value
> (second marker on slider) and it
> now works fine.
Lemme guess, it's now < 256? If so, I'd bet almost anything you're a victim
of a fragmented non-paged pool. I thought I posted something about this a
few days ago, but I don't see it now.
I guess if it's fixed then don't break it , but if you need a larger
buffer you might be able to cure things by changing the serial driver load
order. You can do this by making all other drivers dependant on the serial
driver, except of course any dependencies that the serial driver has.
-SHAWN-
> now works fine.
-SHAWN-
I changed the Receive and Transmit buffer settings in Device Manager -Port settings- Advanced --- to a reduced value (second marker on slider) and it now works fine.
I hope that's it now !!
Thanks for your help.
Ashley
