For additional information:
you will get the need to press some buttons then- print this, print that ,
is it okay and so on.
If you want it more automatically, you can use sendkeys.
There was a long thread about choosing different printer outputs
automaticllay in the past.Search for Shawn
Hope this will get included in the new 7.0 version
But you can also use an automated pdf-archiv program, which redirects all
printer outputs to an pdf file maker and archive it automatically.
Have a look at :
http://www.gotomaxx.com
best regards,
detlef
Von: James Atkin [mailto:JamesA@aerial.co.uk]
Gesendet: 17 November 2003 16:04
An: VRF
Betreff: [vrf] Re: Saving an XY plot from VEE to PDF
An alternative to Acrobat Writer (and by that, I mean free!) can be found
at...
http://sector7g.wurzel6.de/pdfcreator/index_en.htm
It installs in much the same way, i.e. generates a Printer called
'PDFCreator'. I've used this on several occasions and the results look
pretty good!
Enjoy,
James
From: Schlieker, Reiner [mailto:reiner.schlieker@siemens.com]
Sent: 17 November 2003 14:48
To: VRF
Subject: [vrf] Re: Saving an XY plot from VEE to PDF
I assume you mean the full acrobat (the writer) and not just the reader?
Hi Bill,
If you have Adobe Acrobat installed, you should have a printer [driver]
named Adobe PDF.
Look under Start->Settings->Printers
Try specifying this as your printer for VEE then use VEE to print the plot.
I just tried it. The driver prompts you for a filename, it uses VEE.pdf as
the default.
Here is a sample:
....Rob
"Murphy, Bill-J" <Bill-J.Murphy@analog.com>
11/14/2003 04:25 PM
Please respond to "Murphy, Bill-J"
To: VRF <vrf@agilent.com>
cc:
Subject: [vrf] Saving an XY plot from VEE to PDF
Hello all,
I need to generate multiple PDF files from XY plots in VEE. My program will
generate an XY plot from the same function for 8 different conditions. These
plots then need to be assembled in an electronic document format (hence PDF)
for distribution. Any ideas?
Bill Murphy
Product Engineer
Analog Devices, Inc.
DSP&SS Division
Tel: 781-937-2873
Email: bill-j.murphy@analog.com
This message and any attachments are confidential, for the exclusive use of
the addressee and may be legally privileged. Any other distribution, use or
reproduction is unauthorised and prohibited. If you have received this
message in error, please notify the sender immediately and delete the
message from your system.
Visit our internet site at http://www.pilkington.com
Have a look at :
best regards,
detlef
An: VRF
at...
pretty good!
Enjoy,
James
To: VRF
Hi Bill,
named Adobe PDF.
the default.
Here is a sample:
....Rob
11/14/2003 04:25 PM
cc:
Hello all,
Bill Murphy
Product Engineer
DSP&SS Division
Tel: 781-937-2873
