Anders,
"/r" was a type error; sorry
Thans anyway
Hans
Anders Jensen schreef:
> Hello Hans.
> I dont know if it was an type error but you shoud type in "
" and not
> "/r"
> Hope you will make it work
> Best regards
> NEG Micon Control Systems A/S
> Anders Jensen
> "Hans van Zwet" <jvzwet@office.casema.nl>@lvld.agilent.com on 22-03-2002
> 11:32:51
> Sent by: owner-vrf@lvld.agilent.com
> To: vrf@lvld.agilent.com
> cc: Andre van der Velde <avdervel@office.casema.nl>
> Subject: vrf reading strings
> Hi all,
> I am controling a Advantest spectrum analyser through a IEEE-488 interface
> card.
> When I send a command to read the marker value, the spectrum analysers
> sends a
> string back e.g. "MLU 0091.00"+CR+LF (string plus carige return and
> linefeed)
> without using the EOI line.
> The problem is that VEE does not terminate on reading the string. I have
> tried
> to set the read terminator in the on "/r"and "/n" but this made no
> difference.
> Can anyone advice?
> Regards,
> Hans van Zwet
> ____________________________________________________________________________
> Ing. J.M. van Zwet NO - QA
> Tel : +31(0)15-8881211 Brassersplein 2
> mailto:jvzwet@office.casema.nl Postbus 345, 2600 AH Delft
> This is the "vrf" maillist, managed by Majordomo. To send messages to
> this maillist, just email to "vrf@lvld.agilent.com". Subscriptions and
Met vriendelijke groet,
Hans van Zwet
Thans anyway
Hans
> Hello Hans.
" and not
> "/r"
> Best regards
> Anders Jensen
> 11:32:51
> Hi all,
> card.
> sends a
> linefeed)
> tried
> difference.
> Can anyone advice?
> Regards,
> Hans van Zwet
Hans van Zwet
I am controling a Advantest spectrum analyser through a IEEE-488 interface card.
When I send a command to read the marker value, the spectrum analysers sends a
string back e.g. "MLU 0091.00"+CR+LF (string plus carige return and linefeed)
The problem is that VEE does not terminate on reading the string. I have tried
to set the read terminator in the on "/r"and "/n" but this made no difference.
Can anyone advice?
Hans van Zwet
