This sounds very much like the defect I reported to Agilent and was confirmed back in Vee 6. Either it didn't get fixed or it has resurfaced. In my case when cancel or abort was hit, Vee went back to the user's vee.io instead of the embedded io.
Dave
Sent: Tuesday, April 18, 2006 11:44 PM
To: VRF
Subject: RE: [vrf] VEE deletes all your instruments
I did see this ***feature*** with VEE7.5. Indeed very annoying... I think it is happening when the instrument config in the library is different from the main.
This wasn't a
problem in VEE6.
-Vinod
--- "Drago, William @NARDAEAST" <William.Drago@L-3com.com> wrote:
> I just pasted the I/O in from a backup file. Very easy, but still
> annoying...
> From: Joe Flynn [mailto:jflynn@sequoiacommunications.com]
> Sent: Monday, April 17, 2006 5:44 PM
> To: Drago, William @NARDAEAST
> I find that it deletes mine when I hit "cancel" or "abort" when
importing
> from a library, not under normal operation of adding for me.
> Its VERY annoying as I have 20 instruments to go remember what the
address
> is!
> Regards,
> Joe Flynn
> _____
> From: Drago, William @NARDAEAST [mailto:William.Drago@L-3com.com]
> Sent: Mon 4/17/2006 1:46 PM
> To: VRF
> Subject: [vrf] VEE deletes all your instruments
> if you've saved them with your program and then try to import a lib
that
> uses a new instrument that does not yet exist in your program.
> Anyone notice this REALLY annoying feature? Can someone explain to me
why
> this happens? Surely there must be a good reason.
> Perhaps if I understand how this helps me I won't be so &^*%$#
aggravated.
> -Bill
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com
You are currently subscribed to vrf as: Dave.Andersen@gdc4s.com To subscribe please send an email to: "vrf-request@lists.it.agilent.com"
with the word subscribe in the message body.
Dave
To: VRF
This wasn't a
problem in VEE6.
-Vinod
> annoying...
importing
address
> is!
> Regards,
> Joe Flynn
> _____
> To: VRF
that
why
aggravated.
> -Bill
Do You Yahoo!?
Â
Anyone notice this REALLY annoying feature? Can someone explain to me why this happens? Surely there must be a good reason.
Â
Perhaps if I understand how this helps me I won't be so &^*%$# aggravated.
Â
-Bill
This e-mail and subsequent attachments may contain information which is proprietary to L-3 Communications Corporation. The contents shall not be disclosed, copied, distributed or used unless authorized by L-3 Communications Narda - East.
I find that it deletes mine when I hit "cancel" or "abort" when importing from a library, not under normal operation of adding for me.
Â
Its VERY annoying as I have 20 instruments to go remember what the address is!
Â
Joe Flynn
Â
 _____ Â
To: VRF
if you've saved them with your program and then try to import a lib that uses a new instrument that does not yet exist in your program.
Â
Â
Â
-Bill
You are currently subscribed to vrf as: jflynn@sequoiacommunications.com
Dave
To: VRF
This wasn't a
problem in VEE6.
-Vinod
> annoying...
importing
address
> is!
> Regards,
> Joe Flynn
> _____
> To: VRF
that
why
aggravated.
> -Bill
Do You Yahoo!?
when the instrument config in the library is different from the main. This wasn't a
problem in VEE6.
-Vinod
> annoying...
> is!
> Regards,
> Joe Flynn
> _____
> To: VRF
> -Bill
Do You Yahoo!?
-Vinod
> annoying...
> address is!
> Regards,
> Joe Flynn
> _____
> To: VRF
> -Bill
Do You Yahoo!?
