Apart from that, of course!
Â
Actually, I was thinking of some way of getting the device ID from the device manager, in the case where you have lots of COM ports open (eg serial mouse).
Â
Dave
Â
 _____ Â
From: Simon Parfitt [mailto:simonparfitt@hotmail.com]
Sent: 03 May 2006 15:13
To: VRF
Subject: Re: [vrf] change COM port
Â
This will find what com port you have
Â
Â
simon
----- Original Message -----
From: HYPERLINK "mailto:watling@IceraSemi.com"David Watling
To: HYPERLINK "mailto:vrf@agilent.com"VRF
Sent: Wednesday, May 03, 2006 2:41 PM
Subject: RE: [vrf] change COM port
Â
Hi Martin,
You can create a panel which asks the user which COM they wish to use.  The address is 1,2,3… for COM1,COM2,COM3…
I don’t know of an easy way of checking to see which COM port has your device automatically from Vee.
The COM port is assigned to a device by Windows in the device manager (Control panel->system->’hardware’ tab->device manager), so you will have to look there to find out which COM port is assigned. You can also change the COM port here under right-click->properties.
You will need to let Vee see the COM port also, by using the Agilent connection expert.
Â
David Watling
Â
 _____ Â
From: Martin Augenstein [mailto:Martin.Augenstein@multiplexrc.de]
Sent: 03 May 2006 14:33
To: David Watling; VRF
Subject: AW: [vrf] change COM port
Â
Hi Dave,
thank you for the hint, but my next question is, how can I get the address?
Martin
Von: David Watling [mailto:watling@IceraSemi.com]
Gesendet: Mittwoch, 3. Mai 2006 15:01
An: VRF
Betreff: RE: [vrf] change COM port
Hi Martin,
There is a control input on the Direct IO for serial ports, called ‘address’. This will do what you want.  The only difficulty I have found is if you wish to check the buffer contents before doing a read.  For this, you need the ‘Interface event’ box which annoyingly cannot be dynamically assigned a different serial port.  I just created a huge if/then/else function to cater for all the possible serial ports.
Â
Dave Watling
Â
 _____ Â
Sent: 03 May 2006 13:52
To: VRF
Subject: [vrf] change COM port
Â
Hi VEE users,
how can I change the serial COM port while runtime?
The user from the program should have the possibility to
change the COM port.
Thank you for any hints.
Martin
You are currently subscribed to vrf as: watling@icerasemi.com
You are currently subscribed to vrf as: Martin.Augenstein@multiplexrc.de
You are currently subscribed to vrf as: simonparfitt@hotmail.com
Â
Â
Dave
Â
 _____ Â
To: VRF
Â
Â
Â
simon
Â
Hi Martin,
Â
David Watling
Â
 _____ Â
Â
Hi Dave,
Martin
An: VRF
Hi Martin,
Â
Dave Watling
Â
 _____ Â
To: VRF
Â
Hi VEE users,
Martin
<b><span style='font-weight:bold'>Sent:</span></b> 03 May 2006 13:52
<b><span style='font-weight:bold'>To:</span></b> VRF
<b><span style='font-weight:bold'>Subject:</span></b> [vrf] change COM port</span></font><spanlang=EN-US><o:p></o:p></span></p></div><p class=MsoNormal><font size=3 face="Times New Roman"><span style='font-size:12.0pt'><o:p> </o:p></span></font></p><div><p class=MsoNormal><font size=2 face=Arial><span style='font-size:10.0pt;font-family:Arial'>Hi VEE users,</span></font><o:p></o:p></p></div><div><p class=MsoNormal><font size=2 face=Arial><span style='font-size:10.0pt;font-family:Arial'>how can I change the serial COM port while runtime?</span></font><o:p></o:p></p></div><div><p class=MsoNormal><font size=2 face=Arial><span style='font-size:10.0pt;font-family:Arial'>The user from the program should have the possibility to </span></font><o:p></o:p></p></div><div><p class=MsoNormal><font size=2 face=Arial><span style='font-size:10.0pt;font-family:Arial'>change the COM port. </span></font><o:p></o:p></p></div><div><p class=MsoNormal><font size=2 face=Arial><span style='font-size:10.0pt;font-family:Arial'>Thank you for any hints.</span></font><font size=2><spanstyle='font-size:10.0pt'>
</span></font><font size=2 face=Arial><span style='font-size:10.0pt;font-family:Arial'>Martin</span></font><o:p></o:p></p></div><p class=MsoNormal><font size=3 face="Times New Roman"><span style='font-size:12.0pt'>
To subscribe please send an email to:"vrf-request@lists.it.agilent.com" with the word subscribe in themessage body.
To unsubscribe send a blank email to"leave-vrf@it.lists.it.agilent.com".
Search the "unofficial vrf archive" at"www.oswegosw.com/vrf_archive/". <o:p></o:p></span></font></p></div><BR>---<BR>You are currently subscribed to vrf as: rsb@soco.agilent.com<BR>To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body.<BR>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".<BR>To send messages to this mailing list, email "vrf@agilent.com". <BR>If you need help with the mailing list send a message to<BR>"owner-vrf@it.lists.it.agilent.com".<BR>Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/".</BODY></html>
