vrf Very intermittent
Question asked by VRFuser on Mar 17, 2006
"Mairs, David" <david.mairs@hp.com> wrote:
> Thanks for your response,
> The "user object" completes but there is no output From the "from
> file", everything to that point works And the selected file name is in
> the "from file" box.
exactly what I would expect-- there's no output since when you enter this routine the file pointer is already at or near the file end -- ehnce nothing more can be read by the "from file"
> I am not sure how to perform your suggestion:
> check the environment that is calling this routine to make sure that
> the pointer is getting reset properly.
> How do I check the pointer is getting reset?
Either explicitly REWIND the file pointer or close/open the file depending upon what you need to do. I'd have to guess at what your overall program does, but for robustness
add a REWIND before your loop starts
add a CLOSE after the loop finishes
That way your loop always starts at the beginning of the file.
Of course if the file is dynamic it may not have 5 lines like you are trying to read.
Since you are reading in a loop, you probably should read one line at a time.
As it is you will lose data unless your file has a multiple of 5 lines.
Stan
Stan Bischof  Agilent Technologies  707-577-3994  stan_bischof@agilent.com
