Hello!
I see one big problem, no two big problems. One is that OutlookXP which I use for two of my accounts believe they need to block the MDB file, even though it was scanned for viruses twice. Once when you attached it to the GMail screen, and once when it came to my ISP. What say you change the three character last name to say, ".mdk", and advise us to change it back before using? (Quotes mine)
The other is the awful HTML that your using from Gmail it does not display properly on OutlookXP, your better off switching back to standard view who uses plaiotext default.
Gregg C Levine gregg.drwho8@gmail.com
"This signature was once found posting rude messages in English in the Moscow subway."
On 4/16/06, Shawn Fessenden <shawnfess@comcast.net> wrote:
> Delete ADOExample.mdb from your VEE Programs directory. The old and
> new are not compatible.
> Anyway, all this applies only to creating the database. Now that it is
> going to contain Null values, using it is a bigger problem. Anywhere
> VEE is going to access a field, you have to test for Null first or VEE is going to stop.
> VEE 7.5 has the isVariantEmpty and isVariantNull functions to test for
> these conditions, but it's not clear what VEE will do behind the
> scenes when a Null or Empty Field is accessed for it's Value. It's
> probably better to go the VEE 5 route and use a script control.
> -SHAWN-
> You are currently subscribed to vrf as: gregg.drwho8@gmail.com To
> subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body.
> Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/".
> -SHAWN-
</div><div><span class="gmail_quote">On 4/16/06, <b class="gmail_sendername">Shawn Fessenden</b> |<a href="mailto:shawnfess@comcast.net">shawnfess@comcast.net</a>> wrote:</span><blockquote class="gmail_quote" style="PADDING-LEFT: 1ex; MARGIN: 0px 0px 0px 0.8ex; BORDER-LEFT: #ccc 1px solid">> Could you sending an other example or check
> our example and sending some clue.
Ah yes, I see I forgot to allow Null values. Easily fixed.
Thanks for pointing this out.
-SHAWN-
</blockquote></div>
---You are currently subscribed to vrf as: rsb@soco.agilent.comTo subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body.To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to"owner-vrf@it.lists.it.agilent.com".Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/".
-SHAWN-
</blockquote></div>
> Delete ADOExample.mdb from your VEE Programs directory. The old and new are
> not compatible.
> Anyway, all this applies only to creating the database. Now that it is going
> to contain Null values, using it is a bigger problem. Anywhere VEE is going
> VEE 7.5 has the isVariantEmpty and isVariantNull functions to test for these
> conditions, but it's not clear what VEE will do behind the scenes when a
> Null or Empty Field is accessed for it's Value. It's probably better to go
> -SHAWN-
Â
The example sent for you continue with the same problem, could check what the modification is necessary to make us or could you modify the program and send to us.
Â
We are using Operation System Xp (sp2) and Vee 7.5
Â
Â
Assemir/Sidney
Â
On 4/16/06, Shawn Fessenden <HYPERLINK "mailto:shawnfess@comcast.net"shawnfess@comcast.net> wrote:
-SHAWN-
--- To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body. To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/".
Â
Â
Â
Â
Assemir/Sidney
Â
-SHAWN-
> -SHAWN-
