I agree with the last comments by Shawn......basically someone left the building and took the code with them, or left it whatever, aswell as leaving you with custom card.
Â
I think, Look at your inputs and outputs, and rebuild from scratch,
Â
HMI ( Vee will be better than the 15 year program)
Program...Vee will run as faster (than a 10 yr old C program.....because of legacy).
Interface....at least now you are standardising....
Hardware.....give info?......probably replaceable cheaply.
Â
Cost of replacement $<?, ........experience doing it ....priceless
Â
Â
 _____ Â
From: Shawn Fessenden [mailto:shawnfess@comcast.net]
Sent: Mon 4/17/2006 5:39 PM
To: VRF
Subject: RE: [vrf] ActiveX Control and read serial port
> I am not be able to interface with it
> using VEE and not be able read the test
> result in real time. Is there an activeX
> control to do this task?
No.
> How do I read these data through a serial port?
Analyze the original circuitry.
1. There are techniques to connect to a process and control it's input and
read it's output, but only if the original program uses the standard
library. If it's reading the keyboard and writing to the screen without
going through the standard library, you'll have to do a lot of work to
automate it. Brush up on your machine language. You'll need it (i.e., it
ain't gonna happen in VEE - that much is sure).
2. It's a toss up. Either figure out what the original board does or capture
a session and figure it out that way. VEE can handle a serial port just
fine, but RS-232 isn't the only beast out there. There are plenty of wire
protocols that have nothing to do with any published standard.
My opinion is completely redesign and rebuild the test rather than automate
the existing test.
-SHAWN-
You are currently subscribed to vrf as: Willie.Kiely@bourns.com
To send messages to this mailing list, email "vrf@agilent.com".Â
Â
Â
Â
Â
Â
 _____ Â
To: VRF
No.
the existing test.
-SHAWN-
No.
the existing test.
-SHAWN-
