Waitaminute - you said the *second* time through. Hm, that's different. I can't imagine. It's hard to even come up with some scenario that works the first time but throws this the second time. Is there anything hooking COM on this PC?
-SHAWN-
-SHAWN-
Well, Sky says that means "An invalid field name was used in a query
string." Obviously, this is incorrect. IOW, we've encountered that most
hilarious of scenarios, the famous Comp/Edit 5810 "Erroneous Error".
Since this problem is isolated to one particular machine I'd hazard a guess
that the registry is farkled - though farkled in a way I would have thought
impossible. You might want to try running chkdsk. If no problems turn up,
and if a scan & fix of the registry doesn't cure the problem, try
reinstalling Excel.
-SHAWN-
