>Hmm... When I click on About Agilent IO Control, I get 14.1.8016.0. But when I click on Installation Information, I get 14.1.8310.1.
Â
Â
I see the same thing. I guess the patch patched...
Â
Can't help you with the events thing though. Every time I look it crashes...
Â
-Bill
From: Andersen, Dave-P26278 [mailto:Dave.Andersen@gdc4s.com]
Sent: Wednesday, March 08, 2006 1:39 PM
To: Drago, William @NARDAEAST; VRF
Subject: RE: [vrf] IO Suite 14.1 Patch 2
Â
Dave Andersen
Â
P.S. On a similar note, I looked at the Sytem Events Viewer and I see that the following event is occuring every ~7 seconds:
Â
Event Type:Â Information
Event Source:Â Service Control Manager
Event Category:Â None
Event ID:Â 7035
Date:Â Â 3/8/2006
Time:Â Â 11:20:41 AM
User:Â Â AZ25-JH5HS81p26278l
Computer:Â AZ25-JH5HS81
Description:
The GPIB Device Class Driver service was successfully sent a start control.
Â
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp. this normal?????
 _____ Â
From: Drago, William @NARDAEAST [mailto:William.Drago@L-3com.com]
Sent: Wednesday, March 08, 2006 11:21 AM
To: VRF
Subject: [vrf] IO Suite 14.1 Patch 2
All,
Â
I installed the following patch to IO Suite v14.1.8016.0:
Â
Agilent IO Libraries Suite 14.1.8016.0 Patch 2Â , Version 14.1.8310.1, December 6, 2005, 11.5 MB, .exe. Patch 2 includes several defect fixes. Patch 2 also incorporates all defect fixes that were included in IO Libraries Suite 14.1 Patch 1. Do not install Patch 2 if your currently-installed IO Libraries Suite version number is greater than 14.1.8311.0. Later patches will incorporate all defect fixes included in Patch 2.
Â
And, strangely, when I do Help/About my IO Suite still says it's version is v14.1.8016.0.
Â
Is this normal or did my patch not succeed?
Â
Bill
You are currently subscribed to vrf as: Dave.Andersen@gdc4s.com
This e-mail and subsequent attachments may contain information which is proprietary to L-3 Communications Corporation. The contents shall not be disclosed, copied, distributed or used unless authorized by L-3 Communications Narda - East.
Â
Â
Â
Â
-Bill
Â
Dave Andersen
Â
Â
Event ID:Â 7035
Date:Â Â 3/8/2006
Description:
Â
 _____ Â
To: VRF
All,
Â
Â
Â
Â
Â
Bill
I didn't find a GPIB Device Class Driver service, but I did find an
Agilent Technologies gpib-32.dll File Monitor/Renamer service. When I
stopped that service the GPIB service notices also stopped. However,
when I restarted the service the GPIB notices did not return. Maybe
there is some problem with the initial starting of the service. I guess
I need to ask Agilent about this.
Dave
Sent: Wednesday, March 08, 2006 12:12 PM
To: VRF
> Is this normal?????
I wouldn't think so. It bears looking into maybe. If you can find this
service listed in your Services applet, right click it and select
properties. On the Recovery tab, change the "Subsequent failures" drop
down to "Run a Program". In the Program box, type c:itquit.bat. Create
c:itquit.bat:
@echo off
echo It quit again.
pause
If the service is crashing and something else is starting it up, now at
least you'll be notified when it crashes. Of course, you'll get this
window every seven seconds...
service from the command line (i.e. turn off this behavior in the batch
file) but I can't find the syntax.
-SHAWN-
Â
Â
Â
Â
Â
Bill
Â
Dave Andersen
Â
Â
Event ID:Â 7035
Date:Â Â 3/8/2006
Description:
Â
 _____ Â
To: VRF
All,
Â
Â
Â
Â
Â
Bill
I wouldn't think so. It bears looking into maybe. If you can find this service listed in your Services applet, right click it and select properties. On the Recovery tab, change the "Subsequent failures" drop down to "Run a Program". In the Program box, type c:itquit.bat. Create c:itquit.bat:
@echo off
echo It quit again.
pause
If the service is crashing and something else is starting it up, now at least you'll be notified when it crashes. Of course, you'll get this window every seven seconds...
-SHAWN-
I didn't find a GPIB Device Class Driver service, but I did find an Agilent Technologies gpib-32.dll File Monitor/Renamer service. When I stopped that service the GPIB service notices also stopped. However, when I restarted the service the GPIB notices did not return. Maybe there is some problem with the initial starting of the service. I guess I need to ask Agilent about this.
Dave
To: VRF
> Is this normal?????
c:itquit.bat:
@echo off
echo It quit again.
pause
-SHAWN-
Well that much is cool. Poking around really does pay sometimes.
-SHAWN-
