Best thing for you to do is : download the evaluation version and VeeIOLIb14.2 from the web and install it on a separate computer.
Then try to run your programs.
After that you do know
Â
The Evaluation version runs 30 days. tYpe in the code “EVAL†….
Â
So at the end you have no risk …just give it a try ….
Â
Â
detlef
Â
Von: Charles.Stewart@vertu.com [mailto:Charles.Stewart@vertu.com]
Gesendet: Donnerstag, 27. April 2006 12:34
An: VRF
Betreff: FW: [vrf] Upgrade.
Â
Excellent thanks for that. The thought of having to sift through old code isn't one I relish.
Â
Br
Â
Chuck
Â
 _____ Â
From: ext Ulf Jakobsson [mailto:Ulf.Jakobsson@centurion.se]
Sent: 27 April 2006 11:15
To: VRF
Subject: RE: [vrf] Upgrade.
When we did the upgrade, it was from ver 4 to ver 7 and it was more or less without any issues.
The only thing that we had to do was to rename a couple of UFs that where badly named. They used the same name as a varable, ok for ver4 but not for ver7.
Â
Hälsningar/Regards
Ulf Jakobsson
Quality Engineer
Centurion
P.O.Box 500, S-184 24Â Ã…kersberga, Sweden
Tel direct +46 8 555 724 25
e-mail:HYPERLINK "mailto:ulf.jakobsson@centurion.se"ulf.jakobsson@centurion.se
HYPERLINK "outbind://62/www.centurion.com"www.centurion.com
Â
Â
 _____ Â
From: Charles.Stewart@vertu.com [mailto:Charles.Stewart@vertu.com]
Sent: den 25 april 2006 12:36
To: VRF
Subject: [vrf] Upgrade.
Hello All:
We have a number of larger programs (several .vee files as well as some com components) built in Vee project. Ver 6. and we want to upgrade to vee Ver 7. Apparently my predecessor tried un-successfully. Before I start, are there any issues I should be aware of?
Thanks in advance
Chuck Stewart           | Senior Software Engineer
Vertu Ltd       Telephone    +44 1252 611101
Beacon Hill Road        Mobile       +44 7796 276949
Church Crookham  Facsimile    +44 1252 611301
Hampshire GU52 8DY Â Â Â Â charles.stewart@vertu.com
Â
Â
Â
Â
Â
detlef
Â
An: VRF
Â
Â
Br
Â
Chuck
Â
 _____ Â
To: VRF
Â
Hälsningar/Regards
Ulf Jakobsson
Quality Engineer
Centurion
Â
Â
 _____ Â
To: VRF
Hello All:
Thanks in advance
Â
<b><span style='font-weight:bold'>Von:</span></b> Charles.Stewart@vertu.com[mailto:Charles.Stewart@vertu.com]
<b><span style='font-weight:bold'>Gesendet:</span></b> Donnerstag, 27. April2006 12:34
<b><span style='font-weight:bold'>An:</span></b> VRF
<b><span style='font-weight:bold'>Betreff:</span></b> FW: [vrf] Upgrade.</span></font></p><p class=MsoNormal style='margin-left:35.4pt'><font size=3face="Times New Roman"><span style='font-size:12.0pt'> </span></font></p><div><p class=MsoNormal style='margin-left:35.4pt'><font size=2 color=blueface=Arial><span style='font-size:10.0pt;font-family:Arial;color:blue'>Excellentthanks for that. The thought of having to sift through old code isn't oneI relish. </span></font></p></div><blockquote style='border:none;border-left:solid blue 1.5pt;padding:0cm 0cm 0cm 4.0pt;margin-left:3.75pt;margin-top:5.0pt;margin-right:0cm;margin-bottom:5.0pt'><div><p class=MsoNormal style='margin-left:35.4pt'><font size=3face="Times New Roman"><span style='font-size:12.0pt'> </span></font></p></div><div><p class=MsoNormal style='margin-left:35.4pt'><font size=2 color=blueface=Arial><span style='font-size:10.0pt;font-family:Arial;color:blue'>Br</span></font></p></div><div><p class=MsoNormal style='margin-left:35.4pt'><font size=3face="Times New Roman"><span style='font-size:12.0pt'> </span></font></p></div><div><p class=MsoNormal style='margin-left:35.4pt'><font size=2 color=blueface=Arial><span style='font-size:10.0pt;font-family:Arial;color:blue'>Chuck</span></font></p></div><blockquote style='border:none;border-left:solid blue 1.5pt;padding:0cm 0cm 0cm 4.0pt;margin-left:3.75pt;margin-top:5.0pt;margin-right:0cm;margin-bottom:5.0pt'><p class=MsoNormal style='margin-left:35.4pt'><font size=3face="Times New Roman"><span style='font-size:12.0pt'> </span></font></p><div class=MsoNormal align=center style='margin-left:35.4pt;text-align:center'><fontsize=3 face="Times New Roman"><span lang=EN-US style='font-size:12.0pt'><hr size=2 width="100%" align=center></span></font></div><p class=MsoNormal style='margin-right:0cm;margin-bottom:12.0pt;margin-left:35.4pt'><b><font size=2 face=Tahoma><span lang=EN-US style='font-size:10.0pt;font-family:Tahoma;font-weight:bold'>From:</span></font></b><font size=2face=Tahoma><span lang=EN-US style='font-size:10.0pt;font-family:Tahoma'> extUlf Jakobsson [mailto:Ulf.Jakobsson@centurion.se]
<b><span style='font-weight:bold'>Sent:</span></b> 27 April 2006 11:15
<b><span style='font-weight:bold'>To:</span></b> VRF
<b><span style='font-weight:bold'>Subject:</span></b> RE: [vrf] Upgrade.</span></font></p><p class=MsoNormal style='margin-left:35.4pt'><font size=2 color=blueface=Arial><span style='font-size:10.0pt;font-family:Arial;color:blue'>When wedid the upgrade, it was from ver 4 to ver 7 and it was more or less without anyissues.</span></font></p><p class=MsoNormal style='margin-left:35.4pt'><font size=2 color=blueface=Arial><span style='font-size:10.0pt;font-family:Arial;color:blue'>The onlything that we had to do was to rename a couple of UFs that where badly named.They used the same name as a varable, ok for ver4 but not for ver7.</span></font></p><p class=MsoNormal style='margin-left:35.4pt'><font size=3face="Times New Roman"><span style='font-size:12.0pt'> </span></font></p><div><div><div><div><p class=MsoNormal style='margin-left:35.4pt'><font size=2 color=blueface=Arial><span style='font-size:10.0pt;font-family:Arial;color:blue'>Hlsningar/Regards</span></font><fontcolor=blue face=Arial><span style='font-family:Arial;color:blue'>
</span></font><font size=2 color=blue face=Arial><span style='font-size:10.0pt;font-family:Arial;color:blue'>Ulf Jakobsson</span></font><font color=blueface=Arial><span style='font-family:Arial;color:blue'>
</span></font><font size=2 color=blue face=Arial><span style='font-size:10.0pt;font-family:Arial;color:blue'>Quality Engineer</span></font><font color=blueface=Arial><span style='font-family:Arial;color:blue'>
</span></font><font size=2 color=blue face=Arial><span style='font-size:10.0pt;font-family:Arial;color:blue'>Centurion</span></font><font color=blueface=Arial><span style='font-family:Arial;color:blue'>
</span></font><font size=2 color=blue face=Arial><span style='font-size:10.0pt;font-family:Arial;color:blue'>P.O.Box 500, S-184 24 kersberga, Sweden</span></font><fontcolor=blue face=Arial><span style='font-family:Arial;color:blue'>
</span></font><font size=2 color=blue face=Arial><span style='font-size:10.0pt;font-family:Arial;color:blue'>Tel direct +46 8 555 724 25</span></font><fontcolor=blue face=Arial><span style='font-family:Arial;color:blue'>
</span></font><font size=2 color=blue face=Arial><span style='font-size:10.0pt;font-family:Arial;color:blue'>e-mail:</span></font><font size=2 color=blueface=Arial><span lang=EN-GB style='font-size:10.0pt;font-family:Arial;color:blue'><a href="mailto:ulf.jakobsson@centurion.se">ulf.jakobsson@centurion.se</a></span></font><fontsize=2 color=blue face=Arial><span style='font-size:10.0pt;font-family:Arial;color:blue'>
</span></font><font size=2 color=blue face=Arial><span lang=EN-GBstyle='font-size:10.0pt;font-family:Arial;color:blue'><ahref="outbind://62/www.centurion.com">www.centurion.com</a></span></font></p></div></div><p class=MsoAutoSig style='margin-left:35.4pt'><font size=2 color=blueface=Arial><span style='font-size:10.0pt;font-family:Arial;color:blue'> </span></font></p></div></div><p class=MsoNormal style='margin-left:35.4pt'><font size=3face="Times New Roman"><span style='font-size:12.0pt'> </span></font></p><div class=MsoNormal align=center style='margin-left:35.4pt;text-align:center'><fontsize=3 face="Times New Roman"><span lang=EN-US style='font-size:12.0pt'><hr size=2 width="100%" align=center></span></font></div><p class=MsoNormal style='margin-right:0cm;margin-bottom:12.0pt;margin-left:35.4pt'><b><font size=2 face=Tahoma><span lang=EN-US style='font-size:10.0pt;font-family:Tahoma;font-weight:bold'>From:</span></font></b><font size=2face=Tahoma><span lang=EN-US style='font-size:10.0pt;font-family:Tahoma'>Charles.Stewart@vertu.com [mailto:Charles.Stewart@vertu.com]
<b><span style='font-weight:bold'>Sent:</span></b> den 25 april 2006 12:36
<b><span style='font-weight:bold'>Subject:</span></b> [vrf] Upgrade.</span></font></p><p style='margin-left:35.4pt'><font size=2 face=Arial><span style='font-size:10.0pt;font-family:Arial'><!-- Converted from text/rtf format -->Hello All:</span></font></p><p style='margin-left:35.4pt'><font size=2 face=Arial><span style='font-size:10.0pt;font-family:Arial'>We have a number of larger programs (several .veefiles as well as some com components) built in Vee project. Ver 6. and we wantto upgrade to vee Ver 7. Apparently my predecessor tried un-successfully.Before I start, are there any issues I should be aware of?</span></font></p><p style='margin-left:35.4pt'><font size=2 face=Arial><span style='font-size:10.0pt;font-family:Arial'>Thanks in advance</span></font> </p><p style='margin-left:53.4pt'><b><font size=3 face="Times New Roman"><spanlang=EN-GB style='font-size:12.0pt;font-weight:bold'>ChuckStewart |Senior Software Engineer</span></font></b><span lang=EN-GB>
Hampshire GU52 8DY charles.stewart@vertu.com
</span></p></blockquote></blockquote></div><BR>---<BR>You are currently subscribed to vrf as: rsb@soco.agilent.com<BR>To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body.<BR>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".<BR>To send messages to this mailing list, email "vrf@agilent.com". <BR>If you need help with the mailing list send a message to<BR>"owner-vrf@it.lists.it.agilent.com".<BR>Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/".</BODY></html>
