If you switch to 7.5, you also have to switch to IOlib 14.
Best way to make sure that all things works as you want is to take the evaluation version, install it on a test machine and then check what you need.
Download it or order a CD. The Eval version works for 30 days.
Test before buy in this case...
Â
I think ( ImHO)  that Vee 8 will be there somehow parallel to Vista - makes sense
Â
detlef
 _____ Â
Von: JMartinez@tdktca.com [mailto:JMartinez@tdktca.com]
Gesendet: Dienstag, 24. Oktober 2006 23:39
An: VRF
Betreff: [vrf] Upgrade 6.0 to 7.5
We are in the decision phase of upgrading VEE PRO and I was wondering if anyone had any issues with the new program being backwards compatible. Â The call center says that there should be no problems, but I wanted to make sure that there wasn't anything intermittent that would prevent our older programs from running on the newer version. Â Also, has anyone heard when VEE PRO8.0 is supposed to be released?
Best Regards,
John P. Martinez
TDK R&D Corporation
4645 E. Cotton Center Blvd. Â Ste. 199
Phoenix, Arizona 85040
602-458-9011
jmartinez@tdktca.com
--- You are currently subscribed to vrf as: Detlef.Baranski@pilkington.de To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body. To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/".
Â
Â
detlef
 _____ Â
An: VRF
Best Regards,
John P. Martinez
TDK R&D Corporation
602-458-9011
We are trying to communicate with a serial port on a USB to serial adapter but are getting a configuration error (we have tried this on 2 makes of USB to serial units). When we use a standard serial port and a port on a pci card there are no problems. It is important that we can use a usb/serial adapter as we are planning to run the program on laptops.
Have any of you come across this and if so have you found a way round it.
Thanks for your help
Alasdair
Alasdair Chambers
Email: ac@chambers-electronics.com
