Shawn et al,
As suggested, I compared the state information between a good copy and one that has problems - there are no differences. A simplified version of my application has a state number of 640 #H and the normal version, which has a strip chart background picture, has a state number of 465233. These numbers don't change between "good" and "bad" versions.
Barrie
Shawn wrote:
I have one more suggestion, given that now you know it's basically a corrupt data problem. Compare state information from the good copy with that from the bad copy. This will be found in the .vee file and it looks something like this:
(device 3 ACTIVEXCONTROL
(properties
(name "Libs, Classes & Functions")
(variableName "gtv")
(objectType "MSComctlLib.TreeView")
(implementation
(license 37 #H <some license bytes>)
(state 128 #H <state information bytes>)
The number after state indicates how many bytes are in the data, two chars for each byte. If it has to do with corrupt string data, you'll probably find a missing 0 byte. I suppose there are several other possibilities too.
Barrie
(properties
(implementation
seems that the actual cause was this corrupt data even though it did only
come into play when drawing occurred.
like this:
(properties
(implementation
I'm making a note for VV2 to look into trying to validate state information,
but I don't know how much I can do about it. The state usage is all up to
the individual control.
In any case great work! After I found that Ole View puked on instancing it I
basically gave up.
-SHAWN-
