"Doug Rudrow" <dbrudrow@sbcglobal.net> wrote:
> Greetings VRF,
> I'm trying to finish up my first gig as a contractor and I'm stuck
> trying to get trace data from an Anritsu 37397C network analyzer. It
> outputs the data in what the manual calls "arbitrary block", which
> boils down to a giant string of ASCII characters where the values are
> separated by commas. I've tried just about every method of reading the
> data. I started by trying to read "BINBLOCK" 2D array, since I need
> two values for each point on the trace (amplitude and phase). When I
> do this, I get the 2D array, but most of the values show up as zeros.
> The first part of the transmission is a header telling me how many
> characters are contained in the output string. Using this information
> I was able to download the whole string by reading in "CHAR FORMAT"
> using the appropriate number of characters. Now I'm trying to find a
> relatively simple way of separating out the values and saving the data in a meaningful way.
what you descirbe is not a binblock so that won't work
it sounds like regular old comma-separated-data, ala Excel in which case all you need to do is to read in "token"
format, excluding commas, and read an array with "to end" option.
That will read all the values into an array and you'll be set to go.
Stan
> Greetings VRF,
Stan
Â
I’m trying to finish up my first gig as a contractor and I’m stuck trying to get trace data from an Anritsu 37397C network analyzer. It outputs the data in what the manual calls “arbitrary block†, which boils down to a giant string of ASCII characters where the values are separated by commas. I’ve tried just about every method of reading the data. I started by trying to read “BINBLOCK†2D array, since I need two values for each point on the trace (amplitude and phase). When I do this, I get the 2D array, but most of the values show up as zeros. The first part of the transmission is a header telling me how many characters are contained in the output string. Using this information I was able to download the whole string by reading in “CHAR FORMAT†using the appropriate number of characters. Now I’m trying to find a relatively simple way of separating out the values and saving the data in a meaningful way.
Â
One thing I noticed in the manual today is that there is an “enhanced ASCII†formatting mode that replaces the separating commas with linefeeds. I don’t know if this will help me, but it’s worth a try.
The other problem is: I won’t have access to the analyzer until tomorrow (Friday).
Â
Thanks in advance for any advice or assistance,
Â
Doug Rudrow
dBRF Test Solutions
HYPERLINK "mailto:dbrudrow@sbcglobal.net"dbrudrow@sbcglobal.net
Â
Â
Â
Â
> Greetings VRF,
> I'm trying to finish up my first gig as a contractor and I'm stuck trying to
> in what the manual calls "arbitrary block", which boils down to a giant
> string of ASCII characters where the values are separated by commas. I've
> read "BINBLOCK" 2D array, since I need two values for each point on the
> this information I was able to download the whole string by reading in "CHAR
> FORMAT" using the appropriate number of characters. Now I'm trying to find a
> meaningful way.
Stan
