Hi Dave,
Â
curiously I am currently in a similar need for a wrapper. Tis is because I want to read binary data from a serial port and VEE has that special 'feature' to stop reading data when an 0x0A byte is read. **** BTW: if somebody has a workaround, let me know ***
Therefore I am currently experimenting with a VEE wrapper library that uses the Microsoft mscomm.ocx ActiveX control.
My serial port is connected via USB/serial converter and I just made the test that inside the running VEE program the control is 'seeing' the port if it is plugged in, not seeing it if I unplug it, and seeÃng it again if I plug it in again. This is without restarting VEE.
Perhaps that helps you.
Â
Georg Nied
Von: David Watling [mailto:watling@IceraSemi.com]
Gesendet: Donnerstag, 30. März 2006 14:33
An: VRF
Betreff: [vrf] Virtual serial (COM) ports
Hi all,
I have to test a product which presents itself as a virtual COM port (via the PCMCIA interface). So I plug it in to the PC, run a Vee program, get a result, and unplug it. The only thing is, Vee (or the IO libraries) cannot handle a COM port that disappears and re-appears. This means I have to close & re-start Vee for each device I plug in. In a production environment, this would be highly un-satisfactory.
The IO libraries seems quite capable of handling USB devices or GPIB interfaces or TCPIP connections that come & go, just not COM ports.
Â
Questions:
Is this a known bug in the IO libraries?
Is there a Vee based work-around?
Is there another work-around (eg has anyone written a wrapper dll to deal with this?)
Â
Regards
Â
David Watling
You are currently subscribed to vrf as: g.nied@gn-software.de
Â
Â
Georg Nied
An: VRF
Hi all,
Â
Questions:
Â
Regards
Â
David Watling
