Bill's suggestion solved my problem perfectly and fast! Iulia provided an old Ossmann file that didn't work, but is a wonderful bit of programming nevertheless.
Thanks to both Bill and Iulia.
bern muller
----- Original Message -----
To: "VRF" <vrf@agilent.com>
Sent: Tuesday, March 14, 2006 10:40 AM
Subject: Re: [vrf] Algorithm
> Here's one way to do it. First locate all the waveform peaks. Then find
> where the waveform peaks have their maxima and select the first one.
> (See attached file: pulses_max.vee)
> Bill Ossmann
> Philips Ultrasound
> "Bern Muller" <bernhard.muller@dlcdesignaudio.com> wrote on 03/13/2006
> 03:35:05 PM:
>> Attached is a little program to generate a waveform similar to those
>> I need to analyze. I need to find the amplitude and time of the
>> first envelope peak (indicated by the pointer). Not the greater peak
>> occurring later. I always want to find the first one. Is there
>> perhaps a Matlab function that will do this? Or has somebody done
>> this before? Looping is OK if there is nothing faster. I wondered
>> about using the Matlab demodulate function, but that seems difficult as
> well.
>> thanks for any ideas.
>> bern muller
> You are currently subscribed to vrf as: bernhard.muller@dlcdesignaudio.com
> To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the
> word subscribe in the message body.
> Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/".
bern muller
> Bill Ossmann
> Philips Ultrasound
> 03:35:05 PM:
> well.
>> bern muller
I've already done Refresh() but nothing seems to happen. I always have to restart the application just to make the datagrid display a new set of rows and column. Are there other steps required before issuing Refresh()?
Thanks.
Ronald
Sent: Friday, March 10, 2006 9:30 PM
To: VRF
Subject: RE: [vrf] [vrf].Net Controls (How to refresh a datagrid?)
> Informations I got from the web
> shows that doing a datagrid refresh
> is not easy even for those using VB.
I'm not sure why anybody would say that - Refresh() is right there at the top of the hierarchy.
-SHAWN-
You are currently subscribed to vrf as: ronald_padua@itron.com.sg To subscribe please send an email to: "vrf-request@lists.it.agilent.com"
