The data from most network analyzers is a complex number, typically Re and Im pairs
 _____ Â
From: Les Hammer [mailto:Les.Hammer@CompleteTest.com]
Sent: Thursday, March 30, 2006 1:30 PM
To: VRF
Subject: RE: [vrf] 8713B
 >  Attached is the entire file. Â
Â
00034Â *Â 0x20Â Â Â Â Â Â Â ! MLA
00035 * 0x4c  L   ! TALK 12
00036Â <Â 0x23Â Â #Â Â
00037Â <Â 0x34Â Â 4Â Â
00038Â <Â 0x31Â Â 1Â Â
00039Â <Â 0x36Â Â 6Â Â
00040Â <Â 0x30Â Â 0Â Â
00041Â <Â 0x38Â Â 8Â Â
00042 < 0xc0  À Â
00043Â <Â 0x41Â Â AÂ Â
00044 < 0x4e  N Â
00045 < 0xb2  ²  Â
Â
That's a binary block header that says:
  4 Characters in the "number of bytes" number
 1608 bytes to followÂ
Then all your data. The data is binary, so you'd have to have the manual to decode what it means - or take a few good guesses on array types.
Â
~~Les
You are currently subscribed to vrf as: RPratt@symmetricom.com
 _____ Â
To: VRF
Â
00042 < 0xc0  À Â
00044 < 0x4e  N Â
00045 < 0xb2  ²  Â
Â
Â
~~Les
Â
I am working with a 8713B analyzer and I can't figure out how to decode the trace data. I don't have a programming manual for it, so I learned how to talk to it by using the panel driver and spying with the gpib monitor.
Â
So, to read the trace:
FORM REAL,64 <CR><LF>
TRAC CH1FDATA <CR><LF>
Â
Then a a ton of data comes back. How do I decode it? There's a header of some sort?
Â
Bill
Â
Â
Â
This e-mail and subsequent attachments may contain information which is proprietary to L-3 Communications Corporation. The contents shall not be disclosed, copied, distributed or used unless authorized by L-3 Communications Narda - East.
> All,
> some sort?
whats does tha data look like? how about posting the first 50 characters
or so?
Odds are it is a BINBLOCK so you'd read it in BINBLOCK format
Stan
> All,
> of some sort?
whats does tha data look like? how about posting the first 50 characters or so?
Stan
Bill
00032 > 0x0a <LF>
00033 * 0x3f ? ! UNL
00034 * 0x20 ! MLA
00036 < 0x23 #
00037 < 0x34 4
00038 < 0x31 1
00039 < 0x36 6
00040 < 0x30 0
00041 < 0x38 8
00042 < 0xc0
00043 < 0x41 A
Yep -it is indeed a BINBLOCK
the #41608 is the header and it specifices that there are 1608
characters following.
Set up a BINBLOCK transaction ( READ BINBLOCK x REAL 64 ARRAY:* )
with 64 bit real format. You'll have
201 data points popping out.
Stan
Bill
00032 > 0x0a <LF>
00034 * 0x20 ! MLA
00036 < 0x23 #
00037 < 0x34 4
00038 < 0x31 1
00039 < 0x36 6
00040 < 0x30 0
00041 < 0x38 8
00042 < 0xc0
00043 < 0x41 A
Stan
Bill
00032 > 0x0a <LF>
00034 * 0x20 ! MLA
00036 < 0x23 #
00037 < 0x34 4
00038 < 0x31 1
00039 < 0x36 6
00040 < 0x30 0
00041 < 0x38 8
00042 < 0xc0 À
00043 < 0x41 A
Set up a BINBLOCK transaction ( READ BINBLOCK x REAL 64 ARRAY:* ) with 64 bit real format. You'll have
Stan
Â
00042 < 0xc0  À Â
00044 < 0x4e  N Â
00045 < 0xb2  ²  Â
Â
Â
~~Les
Â
Bill
Sent: Thursday, March 30, 2006 4:30 PM
To: 'Drago, William @NARDAEAST'; 'VRF'
Â
00042 < 0xc0  À Â
00044 < 0x4e  N Â
00045 < 0xb2  ²  Â
Â
Â
~~Les
