Hello Monty,
Â
I suppose you'll have to check the Microsoft DAO Object Library in the Active X Automation References. Then the Access Objects will appear in the Function and Object Browser.
Â
Â
Mit freundlichen Grüßen
i. A. Claudia Willging
Dr. Claudia Willging
KRIWAN Testzentrum GmbH & Co. KG
D-74670 Forchtenberg
Tel.: (07947) 9150-0 (Durchwahl 9365) Fax: (07947) 9150-50
claudia.willging@KRIWAN-Testzentrum.de
www.KRIWAN-Testzentrum.de
Von: monty a [mailto:monty1082@gmail.com]
Gesendet: Freitag, 3. November 2006 14:43
An: VRF
Betreff: [vrf] Access Problem!!!
Hello Everyone,
Â
I am having a problem when I am open an example that I got with the VEE cd. I am getting this error "Could not load the following ActiveX reference:
Microsoft DAO 3.5 Object Library Version 4.0. Verify that you have the following component installed on the system" Does anybody know what the problem is? and when I run the program its giving me this error "Invalid ProgID: " DAO.DBEngine.35" Error no 563". I am attachin the program.
Â
One more thing I dont have any Access object in the Function and object browser. Do I need to import any libraries so that I have it?
Â
Thank you
Â
Monty
--- You are currently subscribed to vrf as: claudia.willging@kriwan-testzentrum.de To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body. To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/".
Diese E-Mail enthaelt vertrauliche und/oder rechtlich geschuetzte Informationen. Wenn Sie nicht der richtige Adressat sind oder diese E-Mail irrtuemlich erhalten haben, informieren Sie bitte sofort den Absender und loeschen Sie diese Mail. Das unerlaubte Kopieren sowie die unbefugte Weitergabe dieser Mail ist nicht gestattet.
Eingehende E-Mails mit folgenden Anhangs-Endungen werden aus sicherheitsgründen automatisch abgewiesen:
PIF, SCR, BAT, URL, EXE, COM, DLL, HTA, VBS
This e-mail may contain confidential and/or privileged information. If you are not the intended recipient (or have received this e-mail in error) please notify the sender immediately and delete this e-mail. Any unauthorized copying, disclosure or distribution of the contents in this e-mail is strictly forbidden.
Incoming E-Mails with the following attachement-extensions are automatically rejected for security reasons:
Â
Â
Â
An: VRF
Hello Everyone,
Â
Â
Â
Thank you
Â
Monty
