Hi Arie
         don't use the Clear File at Pre-run option in either and just use the Execute - Clear in a separate To File, using the same filename, at an appropriate point in the program.
Â
Les
----- Original Message -----
From: HYPERLINK "mailto:arief12@netvision.net.il"arief12
To: HYPERLINK "mailto:vrf@agilent.com"VRF
Sent: Saturday, April 01, 2006 9:17 AM
Subject: [vrf] Clear File at Pre-Run
Hi All
I have two objects that both of them are writing to the same file, at different times.
At one of them the option of Clear File at Pre-Run is selected and at the second one is should.
But when I select the option at one of them it automatically selected it at the second one too.
How can I separate between them that each of them will be individual without correlation to the other.
Â
Regards
Arie Fainbrun
Â
You are currently subscribed to vrf as: lesord@ntlworld.com
Â
Les
Hi All
Â
Regards
Arie Fainbrun
Â
Â
Regards
Arie Fainbrun
Â
