This fits also to you:
Â
Â
Or just have a look in the examples/ instrumentIO / InstrManagerIntegrated  folder.
Â
There is:
AgE83xxx-AgN52xxx-AgE880xx-AgN338xx-PNA1.vee
AgE83xxx-AgN52xxx-AgE880xx-AgN338xx-PNA2.vee
Â
Â
Â
There are a lot of treasures.
Not only for the use of 7.5 but also elder versions.
For these not having the actual V7.5 it is worth to download the evaluation version just for these example programs. Some will not work for elder Version, but most of them will do.
Â
In a next Agilent VEE Version the examples should be named in a better way so that you can see instantly what sample is needing what VeeVersion.
Â
Sample programs do help a lot !
Â
Best regards,
detlef
Â
Von: GAO,QI (A-Sonoma,ex1) [mailto:qi_gao@agilent.com]
Gesendet: Freitag, 7. April 2006 07:52
An: VRF
Betreff: RE: [vrf] I'm a new Vee user..trying to connect to a HP34970a
Â
Since you're a VEE 7.51 user, the easiest way to get started with 34970a is go to I/O->Instrument Manager, do a Find Instruments first, then select your 34970a, you should see that the "Load Sample" button on the bottom of your Instrument Manager dialog become enabled. Click on the button, there should be a new VEE session started and pre-loaded with the sample program for 34970A with your particular IO configuration.Â
Â
The sample lets you select from several measurements including temperature measurement.
Â
Btw, most of the other top Agilent instruments should be similarly covered by this feature which was new in VEE 7.5
Â
Qi
Â
Â
Von: arief12 [mailto:arief12@netvision.net.il]
Gesendet: Dienstag, 18. April 2006 11:52
An: VRF
Betreff: [vrf] PNA commands
Â
Hi All
I'm trying to find the driver or gpib commands for PNA E8361A.
I would like to know if someone knows were I can find them, or any programs that I can see the command.
Â
Regards
Arie Fainbrun
Â
You are currently subscribed to vrf as: Detlef.Baranski@pilkington.de
Â
Â
Â
There is:
Â
Â
Â
Â
Â
Â
Best regards,
detlef
Â
An: VRF
Â
Â
Â
Â
Qi
Â
Â
An: VRF
Â
Hi All
Â
Regards
Arie Fainbrun
Â
<b><span style='font-weight:bold'>Von:</span></b> arief12[mailto:arief12@netvision.net.il]
<b><span style='font-weight:bold'>Gesendet:</span></b> Dienstag, 18. April 200611:52
<b><span style='font-weight:bold'>An:</span></b> VRF
<b><span style='font-weight:bold'>Betreff:</span></b> [vrf] PNA commands</span></font></p><p class=MsoNormal style='margin-left:35.4pt'><font size=3face="Times New Roman"><span style='font-size:12.0pt'> </span></font></p><p class=MsoNormal style='margin-left:35.4pt'><font size=2 face=Arial><spanlang=EN-US style='font-size:10.0pt;font-family:Arial'>Hi All </span></font></p><p class=MsoNormal style='margin-left:35.4pt'><font size=2 face=Arial><spanlang=EN-US style='font-size:10.0pt;font-family:Arial'>I'm trying to findthe driver or gpib commands for PNA E8361A.</span></font></p><p class=MsoNormal style='margin-left:35.4pt'><font size=2 face=Arial><spanlang=EN-US style='font-size:10.0pt;font-family:Arial'>I would like to know ifsomeone knows were I can find them, or any programs that I can see the command.</span></font></p><p class=MsoNormal style='margin-left:35.4pt'><font size=2 face=Arial><spanlang=EN-US style='font-size:10.0pt;font-family:Arial'> </span></font></p><p class=MsoNormal style='margin-left:35.4pt'><strong><b><font size=4face="Monotype Corsiva"><span lang=EN-US style='font-size:13.5pt;font-family:"Monotype Corsiva"'>Regards</span></font></b></strong></p><p class=MsoNormal style='margin-left:35.4pt'><strong><b><font size=4 face="Monotype Corsiva"><span lang=EN-US style='font-size:13.5pt;font-family: "Monotype Corsiva"'>Arie Fainbrun</span></font></b></strong></p><p class=MsoNormal style='margin-left:35.4pt'><font size=3face="Times New Roman"><span lang=EN-US style='font-size:12.0pt'> </span></font></p><p class=MsoNormal style='margin-left:35.4pt'><font size=3face="Times New Roman"><span lang=EN-US style='font-size:12.0pt'>
To subscribe please send an email to:"vrf-request@lists.it.agilent.com" with the word subscribe in themessage body.
To unsubscribe send a blank email to"leave-vrf@it.lists.it.agilent.com".
Search the "unofficial vrf archive" at"www.oswegosw.com/vrf_archive/". </span></font></p></div><BR>---<BR>You are currently subscribed to vrf as: rsb@soco.agilent.com<BR>To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body.<BR>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".<BR>To send messages to this mailing list, email "vrf@agilent.com". <BR>If you need help with the mailing list send a message to<BR>"owner-vrf@it.lists.it.agilent.com".<BR>Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/".</BODY></html>
