> I haven't done this before and can't
> see how to delete or rename functions
> in the libraries?
Open the library (File->Open) and edit. It's not a vxe, is it?
-SHAWN-
> in the libraries?
-SHAWN-
To All,
Are variables automatically initialized as null? If not, how do
I initialize them as null?
Dave
To All,
Dave
Ivan Edwards
Senior Engineer,
InfraRed Integrated Systems Ltd.,
Towcester Mill,
Towcester,
Northants (UK).
NN12 6AD.
Tel:Â Â +44 (0)1327 357824
Fax:Â Â +44 (0)1327 357825
Website: www.irisys.co.uk
This e-mail message is confidential and for use by the addressee only. If the message is received by anyone other than the addressee, please return the message to the sender by replying to it and then delete the message from your computer. Internet e-mails are not necessarily secure. InfraRed Integrated Systems Ltd. (IRISYS) does not accept responsibility for changes made to this message after it was sent.
Whilst all reasonable care has been taken to avoid the transmission of viruses, it is the responsibility of the recipient to ensure that the onward transmission, opening or use of this message and any attachments will not adversely affect its systems or data. No responsibility is accepted by IRISYS in this regard and the recipient should carry out such virus and other checks as it considers appropriate.
Â
This e-mail message is confidential and for use by the addressee only. If the message is received by anyone other than the addressee, please return the message to the sender by replying to it and then delete the message from your computer. Internet e-mails are not necessarily secure. InfraRed Integrated System Ltd. does not accept responsibility for changes made to this message after it was sent. Whilst all reasonable care has been taken to avoid the transmission of viruses, it is the responsibility of the recipient to ensure that the onward transmission, opening or use of this message and any attachments will not adversely affect its systems or data. No responsibility is accepted by InfraRed Integrated System Ltd. in this regard and the recipient should carry out such virus and other checks as it considers appropriate.
Ivan Edwards
Senior Engineer,
Towcester Mill,
Towcester,
Northants (UK).
NN12 6AD.
Â
 The .vee file is a text file. Edit and rename functions at will.
~~Les HammerÂ
~~Les HammerÂ
From: Iulia Popovici [mailto:iulia.popovici@urbanet.ch]
Sent: 27 April 2006 03:34 pm
To: Ivan Edwards
Subject: Re: [vrf] merge files
Â
You can change the name of an user function (before merging) : Edit --> Edit UserFunction --> Properties ; after that you have to replace all the Calls pointing for the old name with Calls pointing to the new one.
Â
I hope that will help you.
Â
Regards, Julia
----- Original Message -----
From: HYPERLINK "mailto:ivan.edwards@irisys.co.uk"Ivan Edwards
To: HYPERLINK "mailto:vrf@agilent.com"VRF
Sent: Thursday, April 27, 2006 4:10 PM
Subject: [vrf] merge files
I need to merge a new program with one written some time ago. They both share a common name for two different user functions. I haven't done this before and can't see how to delete or rename functions in the libraries? Is there another way round the problem?
Ivan Edwards
Â
To: Ivan Edwards
Â
Â
Â
Regards, Julia
Ivan Edwards
Â
> in the libraries?
-SHAWN-
