"Rudrow, Doug" <Doug_Rudrow@spectrian.com> wrote:
> I've been playing around with the "dir" command that you've been discussing.
> It's a great tool for me, with one exception, many of the directories on my
> machine and on our network drives have spaces in their name. I'm assuming
> that it's the old DOS naming conventions that prevent me from getting a list
> of files in a directory with a space in the name.
> Is there a way to get around this without re-naming the directories?
Sure- you should be OK by just adding a couple of quotes
dir "\wherever
ame with spaceswhatever"
pretty much the same for any command line work when you use spaces
Stan
dir "\wherever
Stan
Doug Rudrow
Spectrian Inc.
