"HILTON,GRAEME (A-England,ex1)" <graeme_hilton@agilent.com> wrote:
> Hi Richard and all vrfers,
> Here's a challenge. The attached program works with local and mapped drives.
> Can it be made to work with UNC's, i.e. \serverAdirectory1directory2 ?
since dir listing works from command line there's no reason it shouldn't
work from a command line driven by VEE.
C:TEMP>dir \ntbits.soco.agilent.comads2002cdrom
Volume in drive \ntbits.soco.agilent.comads is appsrv
Volume Serial Number is FC77-007D
Directory of \ntbits.soco.agilent.comads2002cdrom
02/21/2002 07:49a <DIR> .
02/21/2002 07:49a <DIR> ..
02/21/2002 08:06a <DIR> disk1
02/21/2002 08:11a <DIR> disk2
0 File(s) 0 bytes
4 Dir(s) 51,773,095,936 bytes free
Stan
0 File(s) 0 bytes
Stan
I have a directory named after a production batch, which contains 20 to 30 sets of test data for individual devices from that batch. Firstly, I want to do an analysis of the data to get the usual statistics on the batch, which would mean opening up the test files and calculating means, max, min, StDev etc.........
Secondly, I would like to be able to analyse all batches (or the last 10 or so) over time and see how the stats. are holding up i.e. some form of simple SPC.
The thing that stumps me to begin with is the best way of selecting the batch name(s). I have used the file selection dialogue before but is there a way of making it a directory selection only and then using that to open all files within it?
Has anyone been here before me and got a better idea on how to do it?
Ivan Edwards
Senior Engineer,
InfraRed Integrated Systems Ltd.,
Towcester Mill,
Towcester,
Northants (UK).
NN12 6AD.
Tel: +44 (0)1327 357824
Fax: +44 (0)1327 357825
Website: www.irisys.co.uk
This e-mail message is confidential and for use by the addressee only. If the message is received by anyone other than the addressee, please return the message to the sender by replying to it and then delete the message from your computer. Internet e-mails are not necessarily secure. InfraRed Integrated Systems Ltd. (IRISYS) does not accept responsibility for changes made to this message after it was sent.
Whilst all reasonable care has been taken to avoid the transmission of viruses, it is the responsibility of the recipient to ensure that the onward transmission, opening or use of this message and any attachments will not adversely affect its systems or data. No responsibility is accepted by IRISYS in this regard and the recipient should carry out such virus and other checks as it considers appropriate.
