vrf EXCEL Problem: "SaveAs" is working with Excel2002 under WIN2k, but not under WIN ME
Question asked by hansolofalcon on Apr 24, 2003
Hello from Gregg C Levine
Regarding WinME, and Win2K. Yes there is a difference. WinME, is an
interim release between Win98, and WinXP. It was simply the last
release of the past century. When XP came out, all pre-Century
releases, including ME, were going to be considered, no longer
supported by its users, by Microsoft. Now we've got a date for Win98,
that is the date when physical support ends for Win98. Its date is
June 30.
Normally all programs come with specifics. A program which was written
on NT, or 2K, will run on 98/ME, et cetera. Unless during the install
process there is a message that says so. However, Excel is part of
Office, and it has to run everywhere. This might be a bug for the
folks at Microsoft to ponder.
Gregg C Levine hansolofalcon@worldnet.att.net
"The Force will be with you...Always." Obi-Wan Kenobi
"Use the Force, Luke." Obi-Wan Kenobi
(This company dedicates this E-Mail to General Obi-Wan Kenobi )
(This company dedicates this E-Mail to Master Yoda )
> -----Original Message-----
> From: hermann.ruckerbauer@infineon.com
> [mailto:hermann.ruckerbauer@infineon.com]
> Sent: Friday, April 25, 2003 8:50 AM
> To: VEE vrf
> Subject: [vrf] EXCEL Problem: "SaveAs" is working with Excel2002
under WIN2k,
> b ut not under WIN ME
> Hello
> One more Question:
> When Starting the Example Excel97a an a PC with Excel2002 under
WIN2k it is
> working fine.
> When doing the same under Excel2002 under WINME we are getting an
> errormessage like this:
>      "SaveAs" method of referenced activeX Object failed
> Is there a difference between WINME and WIN2k ?
> If yes, how to overcome it ?
> If no, why is the example not working on the PC with WINME ?
> Thanks for any response
> Hermann
> You are currently subscribed to vrf as:
> To subscribe send a blank email to
"join-vrf@it.lists.it.agilent.com".
> To send messages to this mailing list,  email
"vrf@it.lists.it.agilent.com".
> If you need help with the mailing list send a message to "owner-
