Ashley
If u buy Richard grier's book the source code and how to use the activex is
in it. Without VB u cannot register MSCOMM on yr machine.
Dean
From: Ashley Derrick [mailto:ashley@smartsolutions.karoo.co.uk]
Sent: 19 November 2003 08:38
To: VRF
Subject: [vrf] Re: Error 445 in ActiveX usage - XMComm
Thanks (once again) Shawn for the excellent Advice. There was no download
attached but I followed your advice and got a lot further. However, seems my
MSCOMM is not licenced on my machine ( I got it from the link recommended by
Paco on the VRF). I therefore dowloaded XMComm (see link below) and this
seems to be getting me a lot further. I now just need to suss all of the
ActiveX commands. I have discovered that I can probably do what I need with
the standard VEE comms. but now I have got this far it seems like a nice
vehicle to start understanding the Active X more, without having to crib
examples and not quite knowing what I am doing.
P.S. If you want to havea licenced copy of MSCOMM do youi have to buy VB or
Visual Studio?
http://ourworld.compuserve.com/homepages/richard_grier/xmcomm.htm
----- Original Message -----
To: "VRF" <vrf@agilent.com>
Sent: Tuesday, November 18, 2003 8:39 PM
> Hi Ashley.
> > Sorry If I am asking dumb questions.
> Everybody knows the only dumb questions are those not asked, so don't feel
> bad about asking!
> > Attached is the example
> Ah yes, I see a couple problems. You declared a variable named MSComm and
> then tried to execute "set MSComm1 = CreateObject(MSComm).
> First, the variable names must match. Second, the argument to CreateObject
> is a string, not something of another type. This is where the error came
> from. VEE tried to access a variable called MSComm to pass it to
> CreateObject, and found that it hadn't been initialized yet. Next, the
name
> of the object you want to create is "MSCommLib.MSComm". Change the name of
> your variable in the declare to MSComm1 and change the CreateObject call
and
> it will work.
> -SHAWN-
> You are currently subscribed to vrf as: ashley@smartsolutions.karoo.co.uk
You are currently subscribed to vrf as: dean.moss@eurothermdrives.com
Dean
To: VRF
Visual Studio?
> Hi Ashley.
> bad about asking!
name
and
> it will work.
> -SHAWN-
Visual Studio?
> Hi Ashley.
> bad about asking!
name
and
> it will work.
> -SHAWN-
