I agree with a lot of the gripes listed and it would be nice to see these
changes implemented. You can already do what you ask for in number two however,
it's just not a function. Using a to string object, just select the time stamp
format with now() providing the input. This gives you several options for what
date and time format you want.
Hope this helps,
Andy Young
Harris Corporation
[mailto:paul_chandler@Agilent.com]
Sent: Thursday, March 28, 2002 11:20 AM
To: vrf@lvld.agilent.com
Subject: RE: vrf Gripes
2. A function that has an input of VEE time (like the output of
now()) and
outputs Day, Month, Year, Hour , Min. and Sec.
Hope this helps,
Andy Young
Harris Corporation
now()) and
Amen to this!
>Did anyone suggest an 'undo' button & shorcut ? a la CTL+Z
>Would it be too much to ask to be able to highlight flow or data lines and
>delete them instead of deleting one line at a time ?
>how about when an object output has the same # of inpu>ts as another
object,
>you can drag the objects together & the lines will connect themselves like
>the xilinx environment ?
>Rob Bonino
Also,
1. The ability to input a Record name when building a record. Like Stan
Bischof's "Build field" function.
2. A function that has an input of VEE time (like the output of now()) and
outputs
