When upgrading from Access 97 to Access 2000 the Object library changes from
DAO 3.5 to DAO 3.6. I have several VEE programs (20+) that use Active-X to
write data using the DAO 3.5 Library. When loading Office 2000 professional
does the DAO 3.5 library get deleted? If so is there a workaround to this
problem? Maybe getting a copy of the DAO 3.5 library and restoring it into
the directory where it used to be?
