This is no problem at all, because Outlook can be called through ActiveX. So
reading an email is possible. Answering a messagebox is more tricky because
usualy you wait for an answer. You have to build your program that you loot
to both. The email and the messagebox.
Best regards
B. Aufenanger
Somatec B. Aufenanger & M. Bernhardt
Jagdweg 7a
D-82041 Deisenhofen
Telefon : (089) 613 984 91
Fax. : (089) 613 981 23
Email : mailto:Aufenanger@somatec.de
homepage : http://www.somatec.com/
Von: owner-vrf@lvld.agilent.com [mailto:owner-vrf@lvld.agilent.com]Im
Auftrag von Kevin.Hasselquist@nokia.com
Gesendet: Freitag, 1. Februar 2002 17:55
An: vrf@lvld.agilent.com
Betreff: vrf Reading e-mail with Vee
Greetings All
I have a routine in an ATE that will e-mail me when the test has finished,
or has encountered certain problems, or is waiting for user input. Does
anyone know if there is a way to have Vee check for a response via e-mail,
and use the response to answer the question posed by a message box?
(I'm using Vee 5 and Microsoft Outlook)
Thanks in advance
K2
Kevin 2 Hasselquist
Senior RF Technician
Nokia Mobile Phones, Inc.
12278 Scripps Summit Drive San Diego, CA 92131
Phone: 858-831-4731 Fax: 858-831-6507
Mobile: 619-322-4288
E-mail: Kevin.Hasselquist@Nokia.com
Best regards
B. Aufenanger
Jagdweg 7a
D-82041 Deisenhofen
Greetings All
Thanks in advance
K2
Kevin 2 Hasselquist
