Has anyone tried to install VeePro 6.0 on an XP machine. I will be needing
to do this soon and would like to know. I will not need any of the IO lib
stuff, just Vee and Peekpoke or JS Payne IO.OCX (Which does support XP) for
parallel port access.
Mark G.
----- Original Message -----
From: "BAYES,SCOTT (A-Loveland,ex1)" <scott_bayes@Agilent.com>
To: "'Scott Thompson'" <SThompson@cmltduk.com>
Cc: "VRF Reflector (E-mail)" <vrf@lvld.agilent.com>
Sent: Tuesday, February 26, 2002 7:43 AM
Subject: RE: vrf XP and VEE
> Scott, VEE 6 and 5 do not support Windows XP. The installers will probably
> fail, though no one here has tried them to see what would happen.
Similarly,
> no one here knows how well revs 6 and 5 might operate in XP, since we
> haven't QAd these combinations, and don't plan to.
> I announced "VEE Next Rev" (aka VEE-NR) on the vrf in Dec. One of its
> features will be full XP support. Will be released some time in the second
> quarter of this year.
> Note that the IO Libraries Revision L.01.00, which is the first rev that
> supports XP, does not support XP Home, just XP Professional. VEE will by
> necessity also not support XP Home, since we use IO Libraries. You can
find
> details of Rev L.01.00 at < http://www.agilent.com/find/iolib >.
> You can't find details of VEE-NR anywhere yet, except here in the vrf
> Sincerely,
> Scott Bayes
> Software Technical Support
> Agilent Technologies, Inc.
> 815 14th Street S.W.
> Loveland, CO, U.S.A. 80537
> 970 679 3799 Tel
> 970 635 6867 Fax
> > -----Original Message-----
> > From: Scott Thompson [mailto:SThompson@cmltduk.com]
> > Sent: Tuesday, February 26, 2002 5:24 AM
> > To: VRF Reflector (E-mail)
> > Subject: vrf XP and VEE
> > Hi Everyone
> > Just a quick question, does ProVee 6.0/HPVee 5.01 run ok on XP Home &
> > Professional?
> > > Regards
> > Scott Thompson
> > Software development engineer
> > Channel Master LTD
> > 5 Commerce park, Brunel road
> > Theale, Berkshire, RG7 4AB
> > United Kingdom
> > TEL:+44(0)1189 306699
> > FAX:+44(0)1189 303996
> > email : sthompson@cmltduk.com
> > _____________________________________________________________________
> > This message has been checked for all known viruses by Star
> > Internet. http://www.star.net.uk/stats.asp or call Star Internet.
> > This is the "vrf" maillist, managed by Majordomo. To send messages to
> > this maillist, just email to "vrf@lvld.agilent.com".
> > Subscriptions and
> > unsubscriptions are done through the address
> > "vrf-request@lvld.agilent.com".
> > If you need details, just send a message containing the text "help"
> > to "vrf-request@lvld.agilent.com".
> this maillist, just email to "vrf@lvld.agilent.com". Subscriptions and
Mark G.
Similarly,
find
> Sincerely,
> Scott Bayes
> 970 679 3799 Tel
> 970 635 6867 Fax
> > Hi Everyone
> > Professional?
> > > Regards
> > Scott Thompson
> > Channel Master LTD
> > United Kingdom
> > Subscriptions and
function that takes the part serial number and makes it the filename when
the new spreadsheet is saved. But now if I test the same part again I would
like Vee to lookup the filename, open the file, add a new sheet, and write
the data in the new sheet.
Can anyone give me an example on how to do the lookup of the file and adding
a new sheet to the workbook?
Also if I insert a new sheet at the end do I need to know how many sheets
were there so that I don't overwrite an old sheet?
Matt Grabowski
