Antwort: vrf How to create a Array 2D ?
Question asked by VRFuser on Jul 10, 2002
Hi all,
>From my point of view, including vee.io in the vee file is an upgrade, although it may not work in all cases. This avoid searching vee.io file into the computer for some defined interfaces.
An additional way to use this, it is to select all equipment as serial0 interface in the vee.io included in the vee file itself, that is all as "not live". In this case it is necessary to ask before executing the main part of the program which is the port number for every connected equipment. Or maybe generate a txt (for example interfaces.txt) information file that could be more flexible and readable for the operator. In this file, port numbers can be changed before execute vee and it can be stored always in the same directory than the vee. In that way it is very easy to codify that has to be read it at the same time global variables are declared and other init functions executed.
In both ways (manually by the operator or by and additional file) can be obtained the correct numbers of ports. Supposing they are known, each Direct I/O object needs to be feed (and activated before executed!) with its good value.
Set all equipment in serial0 means "not live" and vee program does not crash at startup.
-----Mensaje original-----
De: Barrie Walden [mailto:bwalden@whoi.edu]
Enviado el: mircoles, 10 de julio de 2002 17:46
CC: Vee Reflector (E-mail)
Asunto: Re: vrf Vee6 and pointing to the desired vee.io file
I have never figured out how vee.io is supposed to work.  Every time I
try using the standard I/O capabilities, I get into trouble.  Mark's
message and "home" explanation helps but there are still problems.  The
applications I write are intended to run on computers I never see and
certainly don't get to configure.  The operator is expected to plug
sensors into available serial ports, turn on the application, enter some
port assignment information and collect data.  When I write the code, I
have no idea what ports are physically present on the target machine and
I don't know which ones the operator will choose to use.  Inevitably,
when its really important, my application will refuse to load because
some port used during development is not available on the target.
Vee 6.01 seems to have flexibility in how port allocation and
configuration can be handled but I haven't come up with the right
combination.  I want my application to load and then provide the
operator with the ability to designate and configure the serial ports he
has chosen for use with the available sensors. How is this supposed to
be done?
Barrie
whoi
