Thanks a lot for all the support it helped me in a good way
Greetings
Yoeri Arien
Microwave engineer
Emerson & Cuming MWP
Nijverheidstraat 7a
2260 Westerlo
Belgium
(Phone) +32 14562547
(Fax) +32 14562507
Greetings
Yoeri Arien
Microwave engineer
Nijverheidstraat 7a
2260 Westerlo
Belgium
(Fax) +32 14562507
indeed a good way to "hide" those window control buttons. It doesn't stop
user from executing "CTRL+ALT+DEL" command, but I think this is the a window
system command that all other application should at least obey.
Yawbang.
> -----Original Message-----
> From: Gerard Geurts [mailto:gg@ieee.org]
> Sent: 27 August 2002 21:20
> To: VEE vrf
> Subject: [vrf] RE: VEE Close Down
> A more elegant method is as attached, provided by James Atkin
> Cheers,
> Gerard
> ----- Original Message -----
> From: Shawn Fessenden <shawnf@ameritech.net>
> To: VEE vrf <vrf@it.lists.it.agilent.com>
> Sent: Tuesday, August 27, 2002 7:41 PM
> > Chris -
> > > (Roughly equivalent to
> > > adding something like OnClose()
> > > or OnOk() message handlers in
> > > C++ to control the way in witch
> > > a window, dialog or application closes).
> > Or like WM_QUERYENDSESSION and WM_ENDSESSION?
> > Gosh, if only. AFAIK, there's no way to do this. The choice you
> have is to
> > provide an explicit EXIT button and disable the close box. The close box
> can
> > be disabled in the runtime with the -disallowclose command line option.
> > -SHAWN-
> > You are currently subscribed to vrf as: gg@ieee.org
