Hello all,
How can I release VEE's hold on the serial ports while it's still running? I'm sure I've seen this asked before, but I believe the answer was to use Execute Close, and this doesn't work for me.
I'm trying to send some ascii data over a serial port, and then switch to a Modbus OCX to send data over the same port, but the OCX won't initialize because the port is in use by VEE.
Any help would be appreciated.
Reiner Schlieker
Test Equipment Designer
Siemens Milltronics Process Instruments Inc.
Phone: (705) 740-7553
Fax: (705) 740-7692
e-mail: reiners@milltronics.com
Reiner Schlieker
Fax: (705) 740-7692
I have a PC here which has one rs232 port, and 2 rs422 ports. When I search
for instruments in the instrument manager auto discovery area, it finds 4
configured interfaces. The 4th, being a GPIB14. This is not the problem.
The problem is, I have another PC identical to mine with only one rs232 port
and VEE only finds the configured GPIB interface on that PC, no COM ports.
And the main PC I am dealing with now has 3 RS-232 COM ports (and a GPIB
interface) and VEE finds only the GPIB when I do an 'auto discovery' My
program produces an error when I try to talk to one of these COM ports.
Can anyone tell me how to set up my COM ports so that VEE will find them? I
don't know what the differences are between what's going on in my PC and
what is up with the other 2.
Thanks so much,
Rob Bonino
