vrf WWW Browser output/input using VEE
Question asked by VRFuser on Apr 17, 2002
Hi Rob,
Im using Agilent VEE 6.
Im going to try this new example sent by you.
Cheers,
Paul
>From: ramarquardt@ra.rockwell.com
>To: "Paul" <paul_duran1000@hotmail.com>
>Subject: Re: vrf WWW Browser output/input using VEE
>Date: Wed, 17 Apr 2002 08:05:49 -0500
>I made a few changes
>Try these.
>Works best if called from another machine's Netscape browser.
>Works partially with IE.
>Put all these files into a directory and run webserver.vee under VEE 4.01
>I have not tried it with VEE 6.0 PRO yet.
>(See attached file: abbkgnd.gif)(See attached file: util.vee)(See attached
>file: webserver.vee)(See attached file: ticketX.tmp)(See attached file:
>system.log)
>...Rob
><< abbkgnd.gif >>
><< util.vee >>
><< webserver.vee >>
><< ticketX.tmp >>
><< system.log >>
_________________________________________________________________
Join the worlds largest e-mail service with MSN Hotmail.
http://www.hotmail.com
Date: Thu, 18 Apr 2002 07:36:29 -0700 (PDT)
To: claudio.garciacasado@telefonica.es
Subject: Re[4]: vrf Formatting numbers
claudio.garciacasado@telefonica.es wrote:
> Thanks to all you.
> I've found that in VEE5.01 your formula WRITE TEXT a REAL64 STD:1 EOL
> leads to an error.
> Replacing it with  WRITE TEXT a REAL STD:1 EOL    (without 64) it works.
sure. The real32,real64 data types (and others) didn't exist in VEE5
Stan
Stan Bischof  Agilent Technologies  707-577-3994  stan_bischof@agilent.com
