If you want the easy way - you can change the text by using a cyclic button
with 2 enum values.
If you want pretty colours - I would create a couple of nice bitmaps for
"start" and "stop" or whatever, and use the 'custom' feature of the toggle
button to set them as the "on" and "off" images.
Regards
Paul F
"Olbinski,
Craig A (MED)" To: "VEE vrf" <vrf@it.lists.it.agilent.com>
<Craig.Olbinski@med.g cc:
e.com> Subject: [vrf] Modifying buttons in VEE while running
16/10/02 15:03
Please respond to "Olbinski,
Craig A (MED)"
Stationery name:-Untitled-
Hello to all,
Is there a way to change button labels and colors while the program is
running? I have a panel created and I would like to have the start
button change to a stop button once pressed. I would like the color to
change as well. If this seems like an elementary question, I apologize
as this is my first Vee program.
Craig A. Olbinski
GE Repair Development Engineering
Global Repair Operations - Americas
Phone: (414) 747-6873 Fax: (414) 747-6836
Pager: (414) 584-6189 Mail Stop: GA-43
E-Mail: craig.olbinski@med.ge.com
You are currently subscribed to vrf as: Paul.Fowler@raytheon.co.uk
To send messages to this mailing list, email
"vrf@it.lists.it.agilent.com".
Craig A. Olbinski
