vrf Obtainig data from HP 8594E spec analyzer
Question asked by VRFuser on Aug 14, 2001
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN"><html xmlns:v="urn:schemas-microsoft-com:vml" xmlns:o="urn:schemas-microsoft-com:office:office" xmlns:w="urn:schemas-microsoft-com:office:word" xmlns="http://www.w3.org/TR/REC-html40"><head><META HTTP-EQUIV="Content-Type" CONTENT="text/html; charset=iso-8859-1"><meta name=ProgId content=Word.Document><meta name=Generator content="Microsoft Word 9"><meta name=Originator content="Microsoft Word 9"><link rel=File-List href="cid:filelist.xml@01C12575.DE0315B0"><!--[if gte mso 9]><xml> <o:OfficeDocumentSettings>  <o:DoNotRelyOnCSS/> </o:OfficeDocumentSettings></xml><![endif]--><!--[if gte mso 9]><xml> <w:WordDocument>  <w:Zoom>0</w:Zoom>  <w:DocumentKind>DocumentEmail</w:DocumentKind>  <w:EnvelopeVis/> </w:WordDocument></xml><![endif]--><style><!-- /* Font Definitions */@font-face     {font-family:Tahoma;     panose-1:2 11 6 4 3 5 4 4 2 4;     mso-font-charset:0;     mso-generic-font-family:swiss;     mso-font-pitch:variable;     mso-font-signature:553679495 -2147483648 8 0 66047 0;} /* Style Definitions */p.MsoNormal, li.MsoNormal, div.MsoNormal     {mso-style-parent:"";     margin:0in;     margin-bottom:.0001pt;     mso-pagination:widow-orphan;     font-size:12.0pt;     font-family:"Times New Roman";     mso-fareast-font-family:"Times New Roman";}p.MsoAutoSig, li.MsoAutoSig, div.MsoAutoSig     {margin:0in;     margin-bottom:.0001pt;     mso-pagination:widow-orphan;     font-size:12.0pt;     font-family:"Times New Roman";     mso-fareast-font-family:"Times New Roman";}span.EmailStyle15     {mso-style-type:personal-reply;     mso-ansi-font-size:10.0pt;     mso-ascii-font-family:Arial;     mso-hansi-font-family:Arial;     mso-bidi-font-family:Arial;     color:navy;}@page Section1     {size:8.5in 11.0in;     margin:1.0in 1.25in 1.0in 1.25in;     mso-header-margin:.5in;     mso-footer-margin:.5in;     mso-paper-source:0;}div.Section1     {page:Section1;}--></style><!--[if gte mso 9]><xml> <o:shapedefaults v:ext="edit" spidmax="1027"/></xml><![endif]--><!--[if gte mso 9]><xml> <o:shapelayout v:ext="edit">  <o:idmap v:ext="edit" data="1"/> </o:shapelayout></xml><![endif]--></head><body bgcolor=white lang=EN-US style='tab-interval:.5in'><div class=Section1><p class=MsoNormal><span class=EmailStyle15><font size=2 color=navy face=Arial><spanstyle='font-size:10.0pt;mso-bidi-font-size:12.0pt;font-family:Arial'>I believeyou can’t do it directly.<span style="mso-spacerun: yes">  </span>Ask thespectrum analyzer its start and stop, or center and span, and you’ll need tobuild your own spectrum.<o:p></o:p></span></font></span></p><p class=MsoNormal><span class=EmailStyle15><font size=2 color=navy face=Arial><spanstyle='font-size:10.0pt;mso-bidi-font-size:12.0pt;font-family:Arial'><![if !supportEmptyParas]> <![endif]><o:p></o:p></span></font></span></p><p class=MsoAutoSig><!--[if supportFields]><span class=EmailStyle15><font size=2 color=navy face=Arial><span style='font-size:10.0pt;mso-bidi-font-size:12.0pt;font-family:Arial'><span style='mso-element:field-begin'></span><span style="mso-spacerun: yes"> </span>AUTOTEXTLIST s "E-mail Signature" <span style='mso-element:field-separator'></span></span></font></span><![endif]--><b><i><fontcolor=blue face=Tahoma><span style='font-family:Tahoma;color:blue;font-weight:bold;font-style:italic'>Kathy Kiessling<o:p></o:p></span></font></i></b></p><p class=MsoAutoSig><font size=3 color=blue face=Tahoma><span style='font-size:12.0pt;font-family:Tahoma;color:blue'>Senior Test Engineer<o:p></o:p></span></font></p><p class=MsoAutoSig><font size=3 color=blue face=Tahoma><span style='font-size:12.0pt;font-family:Tahoma;color:blue'>Endwave Corporation<o:p></o:p></span></font></p><p class=MsoAutoSig><font size=3 color=blue face=Tahoma><span style='font-size:12.0pt;font-family:Tahoma;color:blue'>(408) 522-3160 ph<o:p></o:p></span></font></p><p class=MsoAutoSig><font size=3 color=blue face=Tahoma><span style='font-size:12.0pt;font-family:Tahoma;color:blue'>(408) 820-2429 pg<o:p></o:p></span></font></p><p class=MsoNormal><!--[if supportFields]><span class=EmailStyle15><font size=2 color=navy face=Arial><span style='font-size:10.0pt;mso-bidi-font-size:12.0pt;font-family:Arial'><span style='mso-element:field-end'></span></span></font></span><![endif]--><spanclass=EmailStyle15><font size=2 color=navy face=Arial><span style='font-size:10.0pt;mso-bidi-font-size:12.0pt;font-family:Arial'><![if !supportEmptyParas]> <![endif]><o:p></o:p></span></font></span></p><p class=MsoNormal style='margin-left:.5in'><font size=2 color=blackface=Tahoma><span style='font-size:10.0pt;font-family:Tahoma;color:black'>-----OriginalMessage-----
<b><span style='font-weight:bold'>From:</span></b> Alejandro Islas[mailto:aislas@kbtel.com]
<b><span style='font-weight:bold'>Sent:</span></b> Tuesday, August 14, 20015:52 PM
<b><span style='font-weight:bold'>To:</span></b> vrf@lvld.agilent.com
<b><span style='font-weight:bold'>Subject:</span></b> vrf Obtainig data from HP8594E spec analyzer</span></font></p><p class=MsoNormal style='margin-left:.5in'><font size=3 face="Times New Roman"><spanstyle='font-size:12.0pt'><![if !supportEmptyParas]> <![endif]><o:p></o:p></span></font></p><p class=MsoNormal style='margin-left:.5in'><font size=2 color=blackface=Arial><span style='font-size:10.0pt;font-family:Arial;color:black'>Hithere, Im controlling this HP spec using an direct I/O output object. I needto obtain the spectrum of a signal for later analysis using Matlab. Im usingthe TRA?; command to obtain the trace of the spectrum and store it on an array.Does anybody know how can I obtain  the frequency value array foreach point of the trace? I need this to be able to store and then rebuild thespectrum .</span></font><font color=black><span style='color:black;mso-color-alt:windowtext'><o:p></o:p></span></font></p><p class=MsoNormal style='margin-left:.5in'><font size=3 color=blackface="Times New Roman"><span style='font-size:12.0pt;color:black'> </span></font><fontcolor=black><span style='color:black;mso-color-alt:windowtext'><o:p></o:p></span></font></p><p class=MsoNormal style='margin-left:.5in'><font size=2 color=blackface=Arial><span style='font-size:10.0pt;font-family:Arial;color:black'>                Thanks in advice</span></font><font color=black><span style='color:black;mso-color-alt:windowtext'><o:p></o:p></span></font></p><p class=MsoNormal style='margin-left:.5in'><font size=2 color=blackface=Arial><span style='font-size:10.0pt;font-family:Arial;color:black'>            Alejandro Islas Lpez
Kb/TEL Telecomunicaciones Mxico</span></font><font color=black><spanstyle='color:black;mso-color-alt:windowtext'><o:p></o:p></span></font></p></div></body></html>
