Thanks a lot for the tips but is there a way to make shure that he always
fills one page, maximizie. Or do I need to find the exact size of the
window?
Greetings
Yoeri
From: Strutt, Michael [SMTP:MStrutt@tycoelectronics.com]
Sent: Wednesday, September 04, 2002 11:47 AM
To: VEE vrf
Cc: VEE vrf (E-mail)
Subject: [vrf] RE: Printing Problem
It doesn't seem to work unless you add it too a user function panel.
where you can either display it or use a label to create your own title.
Regards Mike
From: Yoeri Arien [mailto:y.arien@emerson-cuming-mip.com]
Sent: 04 September 2002 09:43
To: VEE vrf
Subject: [vrf] Printing Problem
Hello
For one of our projects we are making use of a X-Y plot. To use this plot
in our ISO procedure we print it out by making use of the plot pin.
If we do this our title bar is always printed black in the background,
regardless of which background we take.
This only happens when we are working on NT with a deskjet printer and not
on UNIX.
Is there a solution for this problem?
Greetings
Yoeri Arien
Microwave engineer
Emerson & Cuming MWP
Nijverheidstraat 7a
2260 Westerlo
Belgium
(Phone) +32 14562547
(Fax) +32 14562507
<< File: test_label.vee >> << File: ATT00002.txt >>
window?
Greetings
Yoeri
To: VEE vrf
Regards Mike
To: VEE vrf
Hello
on UNIX.
Greetings
Yoeri Arien
Microwave engineer
Nijverheidstraat 7a
2260 Westerlo
Belgium
(Fax) +32 14562507
I got different results with the "print" pin. I didn't realize these two
were different. This is on NT with a desk jet driver.
-SHAWN-
