"Marc Engle <MEngle@rfmd.com> wrote:
> Greetings,
> Anybody know a quick way to separate one array into two arrays (Even
> elements in one, Odd elements to another) short of using a loop to do the
> work. I'm trying to squeeze as much time out of my routine as possible and
> that seems to be where the time is being taken...in the loop. Any help would
> be appreciated. Thanks, all.
> Regards,
> Marc Engle
assuming you know the type of the array and that it divides evenly (has
even number of elements) then the std TO STRING > FROM STRING path should
do the trick.
In this case take your 1D array and write a string
then use the FROM STRING to read this string as a 2D array.
Then your two columns are the even and odd elements. Example attached.
regards
Stan
> Greetings,
> Regards,
> Marc Engle
do the trick.
regards
Stan
