vrf deleting values from a file
Question asked by VRFuser on Oct 24, 2002
Wisam,
      To append to a file you can just open it and write to it as you have
done.  To delete a value though, read the data into your program ( e.g.
into an integer or text array ), identify the value you want to remove and
write it back to the file: overwrite the original file and omit the
appropriate value.
For example: read the example file using READ TEXT, INT32 FORMAT, Array 1D
TO END (*).  Next identify the value you want to omit, say the 3rd value
[element 2 of the array].
Use a To File object and check the 'clear file at pre-run or open' and
write the array as concat(Ary[0:1],Ary[3:*])
Hope that helps.
Mike Watts
