Richard,
I did not see an attachment but I have seen this problem recently.
Either change your range to the opposite shape ( a column seems to work
with a 1D array ) or make your data into a 2D array ( x by 1 ) and try
that. For the latter, if it still does not work try to put the array
through the 'transpose' function.
Hope that helps.
Mike Watts
Message text written by INTERNET:RWalker@GeneralMicrowave.com
>Vee Users,
I am trying to log 51 VNA data points into columns in
Excel.
The problem with the atttached file is that the first point in the array is
written into all 51 cells.
OS: Windows 2000
Vee 6.01
Office 97
Thanks for any help.
Richard A. Walker
Herley - Farmingdale
425 Smith Street
Farmingdale, N.Y. 11735-1198
Direct Voice: (631) 630-2086
Main Voice: (631) 630-2000 X286
Fax: (631) 630-2066
mailto: RWalker@GeneralMicrowave.com<
Hope that helps.
Mike Watts
>Vee Users,
Excel.
OS: Windows 2000
Vee 6.01
Office 97
Richard A. Walker
425 Smith Street
Fax: (631) 630-2066
> command to save the current file.
Save() is a method of the Workbook class. If you haven't given a file name
(i.e., if you didn't open the file in the first place), use SaveAs(filename)
to avoid the Excel SaveAs filename dialog.
Set wbk = CreateObject("Excel.Sheet");
//Write some data.
wbk.SaveAs("MyFile.xls");
-SHAWN-
