Hi Rick,
Try looking at the control input pins to the direct IO object - you can at least change the baudrate and timeout. Remember these are asynchronous i.e. make sure the inputs fire prior to the IO box executing. Once they are fired, the settings remain at this for the other IO boxes until you fire some other control inputs (if that makes sense).
Hope this helps
Andy
Sent: 16 April 2003 20:58
To: VEE vrf
Subject: [vrf] FW: Serial Ports
I'm using VEE 5.01 and need to programmatically change the baud rate,
timeout and buffer size. Can anyone point me in the right directs.
Thanks.
Rick Page
Test/Software Engineer
Futaba Corp. of America
711 State Parkway
Schaumburg, IL 60173
You are currently subscribed to vrf as: SRoberts@cmltduk.com
_____________________________________________________________________
This message has been checked for all known viruses by Star Internet. http://www.star.net.uk/stats.asp or call Star Internet.
You are currently subscribed to vrf as: andy_street@agilent.com
Hope this helps
Andy
To: VEE vrf
Thanks.
Rick Page
711 State Parkway
Thanks.
Rick Page
711 State Parkway
