-----Ursprngliche Nachricht----- Von: Vollink F. [mailto:F.Vollink@gasunie.nl] Gesendet: Mittwoch, 27. Mrz 2002 13:20 An: Vrf (E-mail) Betreff: vrf to string object
<< Datei: Vollink F..vcf >> << Datei: string.vee >> Hi all,
Why does the "To String" object inserts spaces into the output, see string.vee.
regards, Friedrich Vllink Gasunie Research Groningen
<<Vollink F..vcf>> <<string.vee>>
**************************************************************************** ************** This communication is intended only for use by the addressee. It may contain confidential or privileged information. If you receive this communication unintentionally, please let us know by reply immediately. Gasunie does not guarantee that the information sent with this E-mail is correct and does not accept any liability for damages related thereto. **************************************************************************** **************
--------------------------------------------------------------------- This is the "vrf" maillist, managed by Majordomo. To send messages to this maillist, just email to "vrf@lvld.agilent.com". Subscriptions and unsubscriptions are done through the address "vrf-request@lvld.agilent.com". If you need details, just send a message containing the text "help" to "vrf-request@lvld.agilent.com". ---------------------------------------------------------------------
the ToString object has a blank as array separator in the properties.
Best regards
M. Bernhardt
Somatec B. Aufenanger & M. Bernhardt
Jagdweg 7a
D-82041 Deisenhofen
Telefon : (089) 613 984 94
Fax : (089) 613 981 23
Email : mailto:Bernhardt@somatec.de
Homepage : http://www.somatec.com/
An: Vrf (E-mail)
Hi all,
string.vee.
regards,
Friedrich Vllink
