Hi Ashley,
No need that there's really something physically connected to that COM-port in
order to get that error. There's a number of 'sleeping' programs that occupy the
COM-port 'just in case'. Example: For my Palm organizer, there's a software
called 'Hotsync', that loads on boot and stays resident all the time, so I can
do data exchange as soon as I connect my Palm to the serial port, without having
to do anything on the PC. I have to explicitly disable it if I want to use that
COM-port with VEE.
I would suggest to browse the autorun folder as well as the ini files for
programs and tools that use a COM port. If you call the task manager
(Ctrl-Alt-Del...), you have a list of suspects and can work through them one by
one TIL IT WORKS.
Thomas
ASHLEYDER@aol.com wrote:
> Can anyone help, please!
> I have a test rig which uses a .vxe run-time program using Com Port 1
> When my customer installs Run Time version and swaps default vee.io file for
> the file generated from my .vee program he gets the error detailed below. I
> tried the .vxe program on a laptop which has the VEE runtime on it and it
> works fine.
> His PC reports that com1 is present if he looks at the system settings and
> nothing else is connected to com1 (eg mouse)
> Reported error is :
> I/O error or timeout occurred SICL error.Interface
> already in use by non-SICL process.
> Thanks,
> Ashley Derrick
> This is the "vrf" maillist, managed by Majordomo. To send messages to
> this maillist, just email to "vrf@lvld.agilent.com". Subscriptions and
> unsubscriptions are done through the address "vrf-request@lvld.agilent.com".
COM-port with VEE.
one TIL IT WORKS.
Thomas
> works fine.
> Reported error is :
> Thanks,
> Ashley Derrick
works fine.
Reported error is :
Ashley Derrick
