Our company uses a lot of programs developed in VEE for calibration but
lately we have had some problems that I cannot answer.
The programs work with Windows 2K and Runtime 5.0 as well as Excel 2000. The
problem is that "intermittently" the program will hiccup and cause the tests
to immediately say the test failed without ever running the software.
Here's an example of what I mean.
I am calibrating an 8753C on the Minimum R Level and this should take about
5 minutes to run. When the program becomes unstable, it will instantly
finish and say that the unit failed. No data is read and the Excel
spreadsheet is empty.
We have been using this program for the better part of 5 years but have only
recently ran into this. The only thing that I can conclude is that the issue
is with Windows 2K. Are there patches that I am missing? Has anyone else ran
into this?
TIA, Mike
into this?
TIA, Mike
