I've read that the max. firewire cable length is 4.5m, but you can have 16
devices in one chain with 4.5 meters between each other, so that makes a lot
more... however I think that there are some cable manufacturers that say you
can use longer single cables. There are also firewire repeaters that can
increase their length (try OrangeMicro).
Regards.
Fermn Zabalegui.
-----Mensaje original-----
De: owner-vrf@lvld.agilent.com [mailto:owner-vrf@lvld.agilent.com]En nombre
de omer.akbas@arcelik.com
Enviado el: viernes 19 de julio de 2002 13:28
Para: vrf@lvld.agilent.com
Asunto: vrf Max. Firewire Cable Length
Dear All,
I will be getting data from a remote device via firewire interface. Physical
distance between the device and the data acquisition system is an important
parameter. What is the maximum allowed cable length for firewire and is
there any repeaters to increase the length?
Regards
Omer Akbas
Regards.
Fermn Zabalegui.
Dear All,
Regards
Omer Akbas
Regards
Omer Akbas
