vrf 8753 CITI Files ...
Question asked by Dr_joel Employee on Jul 23, 2002
Hello James,
     I don't think you can pull the CITI file data across the GP-IB, as it only writes to the built in floppy disc.  If you are trying to save data to a disc, then read the disc on the PC, I would recommend saving an S2P file.  This gives all 4 S-parameters along with the frequency list in an easy to read way.  I can give you more info on this if that's what you want to do.
If you are trying to pull remote data across the GP-IB, then you need to used OUTPDATA commands.
Again, give me a better idea of your task and I can help you.
Best regards, Joel
From: James Atkin [mailto:James.Atkin@mitectelecom.biz]
Sent: Tuesday, July 23, 2002 2:10 AM
To: vrf@lvld.agilent.com
Subject: vrf 8753 CITI Files ...
Hi All,
Has anyone tried to save a CITI file from an 8753 to a PC ?
Any help would be appreciated.
Many thanks
James
James Atkin BEng(Hons) AMIEE
Software Engineer
Mitec Telecom Ltd
The Arenson Centre
Arenson Way
Dunstable
Bedfordshire
LU5 5UL
