Stan,
ACL's do exist in some flavours of UNIX. In solaris I think this feature was implemented in 2.7 or 2.8.
John Cahill
Test Engineer,
Lucent Technologies,
Blanchardstown Industrial Park,
Blanchardstown,
Dublin 15,
Ireland
phone: +353 1 8864734
Sent: Tuesday, August 20, 2002 8:32 PM
To: VEE vrf
Cc: vrf@it.lists.it.agilent.com
Subject: [vrf] Re: How does one set dir permissions in Windows?
"CHANDLER,PAUL (A-Sonoma,ex1)" <paul_chandler@agilent.com> wrote:
> I run VEE on both UNIX and Windows. I need to change the permissions on a
> UNIX directory. From UNIX it's easy: chmod 777 dir_name. How does one do it in
> Windows through VEE? (The UNIX file system is accessed through SAMBA, so it
> looks like a Windows file system from Windows).
> Thank you,
> Paul Chandler
The equivalent in DOS is the ATTRIB command.
ACL's don't exist in unix so there's not direct comparison with "777"
but it will be pretty close.
ATTRIB [+R | -R] [+A | -A ] [+S | -S] [+H | -H] [[drive:] [path] filename]
[/S [/D]]
+ Sets an attribute.
- Clears an attribute.
R Read-only file attribute.
A Archive file attribute.
S System file attribute.
H Hidden file attribute.
/S Processes matching files in the current folder
and all subfolders.
/D Processes folders as well.
regards
Stan
You are currently subscribed to vrf as: cahillj@lucent.com
John Cahill
Test Engineer,
Blanchardstown,
Dublin 15,
Ireland
To: VEE vrf
> Thank you,
> Paul Chandler
[/S [/D]]
and all subfolders.
regards
Stan
