Hi Richard.
If you using a "short cut" to start vee, check the "start in" property of the "short cut". Probably best to make any changes to a copy of the "short cut".
Regards, Ed.
From: Richard Kleinhenz [mailto:scubaman@us.ibm.com]
Sent: Thursday, October 31, 2002 07:23
To: VEE vrf
Subject: [vrf] Where does Vee open files?
When I try to do a 'file open' or 'save as' I see s strange default
directory. Down a directory tree structure where I store data, on my e:
drive. Vee is installed on my d: drive. I thought it should present me
with a listing of files in the directory identified as UserDir in the
registry in HKLM/software/agilent/Vee pro/6.0 and that has
UserDir=D:AgilentVEE Pro 6.0programs. The Vee version I am running is
6.03, and this is under win2k. Any ideas why this might be happening?
Rich
Richard Kleinhenz
845-892-2617
You are currently subscribed to vrf as: E.Cernek@motorola.com
