"MORRISON,SCOTT (A-Sonoma,ex1)" <scott_morrison@agilent.com> wrote:
> Hello fellow VRF'ers,
> I'm hoping someone out there can help me identify what it is about the
> attached prog that causes an apparent memory leak. It's a straightforward
> little (6.1) prog using the now() function to toggle an output every XX hours.
I'd have to suggest that the best way to approach a problem like this
is to use the OS' built-in mechanisms first.
Rather than leaving a process running, use the "at" command
to schedule a regularly-run task to do what you want. Or use
the "scheduled tasks" pick in the Control Panel to access this
via a GUI.
This is much more of a robust solution than any running process.
Even survives across reboots, power outages, whatever.
Stan
via a GUI.
Stan
Could someone refresh my memory about the memory leak somehow associated
with error pins? I have this vague recollection that using an error pin
causes a memory leak at least on some systems, I don't know whether it
simply needs to be connected, or whether something needs to be cleared
explicitly after it fires.
Rich
Richard Kleinhenz
Wafer Engineering
845-892-2617
scubaman@us.ibm.com
"Pickles, Warren"
<Warren.Pickles@tycoelect To: "VEE vrf" <vrf@it.lists.it.agilent.com>
ronics.com> cc:
Subject: [vrf] RE: Is Excel installed?
11/07/2002 10:16 AM
Please respond to
"Pickles, Warren"
Thanks for all the replies to that. CreateObject in a formula box, with an
error output, works fine.
Warren Pickles
Sent: 07 November 2002 08:03
To: VEE vrf
Subject: [vrf] Is Excel installed?
Hi
Does anyone know how to query whether Excel is installed on a given PC,
from
VEE?
Warren Pickles
You are currently subscribed to vrf as: Warren.Pickles@tycoelectronics.com
You are currently subscribed to vrf as: scubaman@us.ibm.com
