after getting this response (thanks to Bruno) I read the manual again, and
here it is mentioned as you described
(* is only working for some special read (e. g. read from file), but not for
Read from GPIB).
So the only solution I found so far is to read byte by byte until an error
occurs. This works fine,
but it takes a long time until the sequence is finished.
Any better idea how to utilze the binblock read ?
thanks
Hermann
Infineon Technologies
Hermann Ruckerbauer
MP TI PD DES 5 / MchB / Room 3448
Balanstrasse 73
D-81541 Munich
Germany
Phone: +49 (89) 234 25041
Fax.: +49 (89) 234 715757
e-mail:Hermann.Ruckerbauer@infineon.com
Von: Beliveau, Bruno [mailto:BrunoBeliveau@solectron.com]
Gesendet am: Montag, 13. Januar 2003 22:49
An: VEE vrf
Cc: VEE vrf
Betreff: [vrf] Re: File transfer over GPIB ==> * as READ BINARY until EOF
not possible ????
With a file I/O transaction, you click on the "Size:" button and it changes
to "To End" (and the quantity to "*"). With a GPIB I/O transaction, the EOF
is not defined (not to my knowledge), so the same trick does not work.
-----Message d'origine-----
De: hermann.ruckerbauer@infineon.com [
mailto:hermann.ruckerbauer@infineon.com
<mailto:hermann.ruckerbauer@infineon.com> ]
Date: 13 janvier 2003 08:19
I have tried the program send by Phil (thanks a lot, see his mail below),
but my VEE (v6) is reporting an error, when it detects a # sign in the
binary
data flow. So I tried the pure binary transfer.
This works fine, if I do know, how much data is transfered, as I can give
the size of the 1dim array I'm going to transfer.
unfortinally I do not know how big the file is I would like to transfer.
Therefore I took a look to the advanced programming guide which says on page
526 that a * will do a read binary until EOF. But when trying to write a
star
into the corresponding "NumElements" field of the direct IO object VEE is
reporting a syntax error, when pressing OK to accept the command!
Is this a bug OR something wrong in the handbook OR am I just to stupid do
use it correct ????
Von: Phil McRevis [ mailto:philmcrevis@hotmail.com
<mailto:philmcrevis@hotmail.com> ]
Gesendet am: Dienstag, 10. Dezember 2002 15:48
Perhaps this will help, but PLEASE excuse me if this attachment is not
appropriate. Even though my days of code development are largely over, I
can't break away from looking at this group every now and then. Is this
group similar to crack? Maybe. Gotta get a fix!
Anyway, I used to use this program to transfer scope images via gpib. While
I don't have a licensed copy of VEE at my disposal right now to verify this
attachment (I suppose I could look at it in notepad), I recall using a
binblock transfer to accomplish this task.
Obviously, some customization will be necessary based on the potential
unique commands of your individual scope(s), but that should be a simple
investigation. First issue the command in an I/O transaction object to send
the scope image, then perform a binblock read of byte array format.
I also recall preferring this simple little program because I didn't like
the dependence of IntuiLink. Hey, if I can get the job done with one or two
simple VEE objects, why bog myself down with IntuiLink?
>From: "Jay Nemeth-Johannes" <jayj@ventureconsult.com>
>Reply-To: "Jay Nemeth-Johannes" <jayj@ventureconsult.com>
>I think you will need to be more specific in order to get an answer.
>IntuiLink for the scope uses a set of documented scope commands for
>transferring a bitmap screen image. The spectrum analyzers use a similar
>capability for a printer dump and then interpret the pcl codes to recreate
>the image. In both cases, the commands to get the screen image exist in
>the instrument.
>If you want the same thing for a non-Agilent instrument, you are going to
>have to read the programming manual and see if the capability exists. If
>it doesn't, which is often the case, your only option is to pull the trace
>data and manually create the rest of the screen with an external graphics
>pack and then re-import.
>-----Original Message-----
>From: Dale Hauck [ mailto:dhauck@Anadigics.com
<mailto:dhauck@Anadigics.com> ]
>Sent: Wednesday, December 04, 2002 1:32 PM
> Specifically image files, screen capture from an instrument.
>Agilent uses Intuilink to overcome this. What can we do for non- Agilent
>instruments? I am unable to get source code for Intuilinks screen capture.
>Anyone?
> The key seems to be in editing the header information to reflect the
>appropriate file format.
You are currently subscribed to vrf as: hermann.ruckerbauer@infineon.com
Read from GPIB).
thanks
Hermann
Hermann Ruckerbauer
Balanstrasse 73
D-81541 Munich
Germany
An: VEE vrf
Cc: VEE vrf
not possible ????
binary
star
use it correct ????
>the instrument.
>Anyone?
